Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS6598X Host Interface Utility Tool
Guru 29710 points
Other Parts Discussed in Thread: TPS65982-HIUTILITY, TPS65986EVM
Hi Team,
I tried to install "TPS6598X Host Interface Utility Tool" from following link.
http://www.ti.com/tool/TPS65982-HIUTILITY?keyMatch=TPS65982&tisearch=Search-EN-Everything
However I couldn't launch the tool because my PC is Windows 32bit.
Could you give me the .exe file for Windows 32bit?
Yaita / Japan disty
  • Yaita-san,
    I understand your problem. I will see if I can get a 32-bit version of the Tool published and posted to the Web.
    The cycle time on posting the new SW is 2-3 business days due to approval and web queuing, so please be patient while I try to get help for you.
  • Hi Brian-san,
    I appreciate for your kind support!
    I will wait as you said.
    Yaita
  • Yaita-san,
    I received a notification that a new version of the TPS65982-HIUTILITY Tool with a 32-bit installer has been built and is currently being tested.
    There are a lot of new features added that need to be checked for bugs in the tool, but once it appears to be stable it will be released to the Web.
  • Hi Brian-san,
    Thank you for your information.
    I wil wait for it.
    Yaita
  • Yaita-san,
    Version 2.3 of the TPS65982-HIUTILITY Tool with a 32-bit installer .exe file is available for TI-employees to download today (Sales Reps and FAEs), and it will be available TI.com in 1-2 business days.
  • Yaita-san,
    I downloaded the TPS65982-HIUTILITY today from the website and verified that the Document # has been updated from "slvc639b" to "slvc639c", the Version # of the SW has been updated to v2.3 and the Zip folder includes a 64-bit and 32-bit installer.
    The 32-bit installer is named "windows_32bit_tps6598x_hostinterface_utilities_2_3.exe"
  • Hi Brian-san,
    Thanks to your support, I could install 32bit installer without fail.
    However I couldn't establish a connection to the TPS65986EVM as the following.
    I connected the TPS65986EVM to the Aardvark SPI Pins correctly as the following link shows (page 17).
    http://www.tij.co.jp/jp/lit/ug/slvuan9a/slvuan9a.pdf
    Is there any concern?
    Your help would be appreciated.
    Yaita
  • Yaita-san,
    Due to the fact that the Aardvark is not explicitly installed by the tool (Aardvark driver, .dll, and .py Python scripts), the associated files need to be added manually to the folder.
    The files are attached in this post, and below is a screen shot showing that I dragged/dropped these files from another location into the TPS65982-HIUTILITY installation folder on my PC:
    aardvark.dll
    aardvark_py.py
    # Aardvark Interface Library
    # Copyright (c) 2002-2008 Total Phase, Inc.
    # All rights reserved.
    # www.totalphase.com
    # Redistribution and use in source and binary forms, with or without
    # modification, are permitted provided that the following conditions
    # are met:
    # - Redistributions of source code must retain the above copyright
    #   notice, this list of conditions and the following disclaimer.
    # - Redistributions in binary form must reproduce the above copyright
    #   notice, this list of conditions and the following disclaimer in the
    #   documentation and/or other materials provided with the distribution.
    # - Neither the name of Total Phase, Inc. nor the names of its
    #   contributors may be used to endorse or promote products derived from
    #   this software without specific prior written permission.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    # "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    # LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
    # FOR A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE
    # COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    # INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    # BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    # LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
    # CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
    # LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
    # ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
    # POSSIBILITY OF SUCH DAMAGE.
    # To access Aardvark devices through the API:
    # 1) Use one of the following shared objects:
    #      aardvark.so      --  Linux shared object
    #      aardvark.dll     --  Windows dynamic link library
    # 2) Along with one of the following language modules:
    #      aardvark.c/h     --  C/C++ API header file and interface module
    #      aardvark_py.py   --  Python API
    #      aardvark.bas     --  Visual Basic 6 API
    #      aardvark.cs      --  C# .NET source
    #      aardvark_net.dll --  Compiled .NET binding
    # VERSION
    AA_API_VERSION    = 0x050a   # v5.10
    AA_REQ_SW_VERSION = 0x050a   # v5.10
    import os
    import sys
    try:
        import aardvark as api
    except ImportError, ex1:
        import imp, platform
        ext = platform.system() in ('Windows', 'Microsoft') and '.dll' or '.so'
        try:
            api = imp.load_dynamic('aardvark', 'aardvark' + ext)
        except ImportError, ex2:
            import_err_msg  = 'Error importing aardvark%s\n' % ext
            import_err_msg += '  Architecture of aardvark%s may be wrong\n' % ext
            import_err_msg += '%s\n%s' % (ex1, ex2)
            raise ImportError(import_err_msg)
    AA_SW_VERSION      = api.py_version() & 0xffff
    AA_REQ_API_VERSION = (api.py_version() >> 16) & 0xffff
    AA_LIBRARY_LOADED  = \
        ((AA_SW_VERSION >= AA_REQ_SW_VERSION) and \
         (AA_API_VERSION >= AA_REQ_API_VERSION))
    from array import array, ArrayType
    import struct
    # HELPER FUNCTIONS
    def array_u08 (n):  return array('B', '\0'*n)
    def array_u16 (n):  return array('H', '\0\0'*n)
    def array_u32 (n):  return array('I', '\0\0\0\0'*n)
    def array_u64 (n):  return array('K', '\0\0\0\0\0\0\0\0'*n)
    def array_s08 (n):  return array('b', '\0'*n)
    def array_s16 (n):  return array('h', '\0\0'*n)
    def array_s32 (n):  return array('i', '\0\0\0\0'*n)
    def array_s64 (n):  return array('L', '\0\0\0\0\0\0\0\0'*n)
    def array_f32 (n):  return array('f', '\0\0\0\0'*n)
    def array_f64 (n):  return array('d', '\0\0\0\0\0\0\0\0'*n)
    # STATUS CODES
    # All API functions return an integer which is the result of the
    # transaction, or a status code if negative.  The status codes are
    # defined as follows:
    # enum AardvarkStatus
    # General codes (0 to -99)
    AA_OK                        =    0
    AA_UNABLE_TO_LOAD_LIBRARY    =   -1
    AA_UNABLE_TO_LOAD_DRIVER     =   -2
    AA_UNABLE_TO_LOAD_FUNCTION   =   -3
    AA_INCOMPATIBLE_LIBRARY      =   -4
    AA_INCOMPATIBLE_DEVICE       =   -5
    AA_COMMUNICATION_ERROR       =   -6
    AA_UNABLE_TO_OPEN            =   -7
    AA_UNABLE_TO_CLOSE           =   -8
    AA_INVALID_HANDLE            =   -9
    AA_CONFIG_ERROR              =  -10
    # I2C codes (-100 to -199)
    AA_I2C_NOT_AVAILABLE         = -100
    AA_I2C_NOT_ENABLED           = -101
    AA_I2C_READ_ERROR            = -102
    AA_I2C_WRITE_ERROR           = -103
    AA_I2C_SLAVE_BAD_CONFIG      = -104
    AA_I2C_SLAVE_READ_ERROR      = -105
    AA_I2C_SLAVE_TIMEOUT         = -106
    AA_I2C_DROPPED_EXCESS_BYTES  = -107
    AA_I2C_BUS_ALREADY_FREE      = -108
    # SPI codes (-200 to -299)
    AA_SPI_NOT_AVAILABLE         = -200
    AA_SPI_NOT_ENABLED           = -201
    AA_SPI_WRITE_ERROR           = -202
    AA_SPI_SLAVE_READ_ERROR      = -203
    AA_SPI_SLAVE_TIMEOUT         = -204
    AA_SPI_DROPPED_EXCESS_BYTES  = -205
    # GPIO codes (-400 to -499)
    AA_GPIO_NOT_AVAILABLE        = -400
    # I2C bus monitor codes (-500 to -599)
    AA_I2C_MONITOR_NOT_AVAILABLE = -500
    AA_I2C_MONITOR_NOT_ENABLED   = -501
    # GENERAL TYPE DEFINITIONS
    # Aardvark handle type definition
    # typedef Aardvark => integer
    # Deprecated type definitions.
    # These are only for use with legacy code and
    # should not be used for new development.
    # typedef aa_u08 => integer
    # typedef aa_u16 => integer
    # typedef aa_u32 => integer
    # typedef aa_s08 => integer
    # typedef aa_s16 => integer
    # typedef aa_s32 => integer
    # Aardvark version matrix.
    # This matrix describes the various version dependencies
    # of Aardvark components.  It can be used to determine
    # which component caused an incompatibility error.
    # All version numbers are of the format:
    #   (major << 8) | minor
    # ex. v1.20 would be encoded as:  0x0114
    class AardvarkVersion:
        def __init__ (self):
            # Software, firmware, and hardware versions.
            self.software      = 0
            self.firmware      = 0
            self.hardware      = 0
            # Firmware requires that software must be >= this version.
            self.sw_req_by_fw  = 0
            # Software requires that firmware must be >= this version.
            self.fw_req_by_sw  = 0
            # Software requires that the API interface must be >= this version.
            self.api_req_by_sw = 0
    # GENERAL API
    # Get a list of ports to which Aardvark devices are attached.
    # nelem   = maximum number of elements to return
    # devices = array into which the port numbers are returned
    # Each element of the array is written with the port number.
    # Devices that are in-use are ORed with AA_PORT_NOT_FREE (0x8000).
    # ex.  devices are attached to ports 0, 1, 2
    #      ports 0 and 2 are available, and port 1 is in-use.
    #      array => 0x0000, 0x8001, 0x0002
    # If the array is NULL, it is not filled with any values.
    # If there are more devices than the array size, only the
    # first nmemb port numbers will be written into the array.
    # Returns the number of devices found, regardless of the
    # array size.
    AA_PORT_NOT_FREE = 0x8000
    def aa_find_devices (devices):
        """usage: (int return, u16[] devices) = aa_find_devices(u16[] devices)
        All arrays can be passed into the API as an ArrayType object or as
        a tuple (array, length), where array is an ArrayType object and
        length is an integer.  The user-specified length would then serve
        as the length argument to the API funtion (please refer to the
        product datasheet).  If only the array is provided, the array's
        intrinsic length is used as the argument to the underlying API
        function.
        Additionally, for arrays that are filled by the API function, an
        integer can be passed in place of the array argument and the API
        will automatically create an array of that length.  All output
        arrays, whether passed in or generated, are passed back in the
        returned tuple."""
        if not AA_LIBRARY_LOADED: return AA_INCOMPATIBLE_LIBRARY
        # devices pre-processing
        __devices = isinstance(devices, int)
        if __devices:
            (devices, num_devices) = (array_u16(devices), devices)
        else:
            (devices, num_devices) = isinstance(devices, ArrayType) and (devices, len(devices)) or (devices[0], min(len(devices[0]), int(devices[1])))
            if devices.typecode != 'H':
                raise TypeError("type for 'devices' must be array('H')")
        # Call API function
        (_ret_) = api.py_aa_find_devices(num_devices, devices)
        # devices post-processing
        if __devices: del devices[max(0, min(_ret_, len(devices))):]
        return (_ret_, devices)
    # This function is the same as aa_find_devices() except that
    # it returns the unique IDs of each Aardvark device.  The IDs
    # are guaranteed to be non-zero if valid.
    # The IDs are the unsigned integer representation of the 10-digit
    # serial numbers.
    def aa_find_devices_ext (devices, unique_ids):
        """usage: (int return, u16[] devices, u32[] unique_ids) = aa_find_devices_ext(u16[] devices, u32[] unique_ids)
        function.
        returned tuple."""
        if __devices:
        else:
        # unique_ids pre-processing
        __unique_ids = isinstance(unique_ids, int)
        if __unique_ids:
            (unique_ids, num_ids) = (array_u32(unique_ids), unique_ids)
        else:
            (unique_ids, num_ids) = isinstance(unique_ids, ArrayType) and (unique_ids, len(unique_ids)) or (unique_ids[0], min(len(unique_ids[0]), int(unique_ids[1])))
            if unique_ids.typecode != 'I':
                raise TypeError("type for 'unique_ids' must be array('I')")
        # Call API function
        (_ret_) = api.py_aa_find_devices_ext(num_devices, num_ids, devices, unique_ids)
        # unique_ids post-processing
        if __unique_ids: del unique_ids[max(0, min(_ret_, len(unique_ids))):]
        return (_ret_, devices, unique_ids)
    # Open the Aardvark port.
    # The port number is a zero-indexed integer.
    # The port number is the same as that obtained from the
    # aa_find_devices() function above.
    # Returns an Aardvark handle, which is guaranteed to be
    # greater than zero if it is valid.
    # This function is recommended for use in simple applications
    # where extended information is not required.  For more complex
    # applications, the use of aa_open_ext() is recommended.
    def aa_open (port_number):
        """usage: Aardvark return = aa_open(int port_number)"""
        # Call API function
        return api.py_aa_open(port_number)
    # Open the Aardvark port, returning extended information
    # in the supplied structure.  Behavior is otherwise identical
    # to aa_open() above.  If 0 is passed as the pointer to the
    # structure, this function is exactly equivalent to aa_open().
    # The structure is zeroed before the open is attempted.
    # It is filled with whatever information is available.
    # For example, if the firmware version is not filled, then
    # the device could not be queried for its version number.
    # This function is recommended for use in complex applications
    # where extended information is required.  For more simple
    # applications, the use of aa_open() is recommended.
    class AardvarkExt:
            # Version matrix
            self.version  = AardvarkVersion()
            # Features of this device.
            self.features = 0
    def aa_open_ext (port_number):
        """usage: (Aardvark return, AardvarkExt aa_ext) = aa_open_ext(int port_number)"""
        # Call API function
        (_ret_, c_aa_ext) = api.py_aa_open_ext(port_number)
        # aa_ext post-processing
        aa_ext = AardvarkExt()
        (aa_ext.version.software, aa_ext.version.firmware, aa_ext.version.hardware, aa_ext.version.sw_req_by_fw, aa_ext.version.fw_req_by_sw, aa_ext.version.api_req_by_sw, aa_ext.features) = c_aa_ext
        return (_ret_, aa_ext)
    # Close the Aardvark port.
    def aa_close (aardvark):
        """usage: int return = aa_close(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_close(aardvark)
    # Return the port for this Aardvark handle.
    def aa_port (aardvark):
        """usage: int return = aa_port(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_port(aardvark)
    # Return the device features as a bit-mask of values, or
    # an error code if the handle is not valid.
    AA_FEATURE_SPI = 0x00000001
    AA_FEATURE_I2C = 0x00000002
    AA_FEATURE_GPIO = 0x00000008
    AA_FEATURE_I2C_MONITOR = 0x00000010
    def aa_features (aardvark):
        """usage: int return = aa_features(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_features(aardvark)
    # Return the unique ID for this Aardvark adapter.
    # IDs are guaranteed to be non-zero if valid.
    # The ID is the unsigned integer representation of the
    # 10-digit serial number.
    def aa_unique_id (aardvark):
        """usage: u32 return = aa_unique_id(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_unique_id(aardvark)
    # Return the status string for the given status code.
    # If the code is not valid or the library function cannot
    # be loaded, return a NULL string.
    def aa_status_string (status):
        """usage: str return = aa_status_string(int status)"""
        # Call API function
        return api.py_aa_status_string(status)
    # Enable logging to a file.  The handle must be standard file
    # descriptor.  In C, a file descriptor can be obtained by using
    # the ANSI C function "open" or by using the function "fileno"
    # on a FILE* stream.  A FILE* stream can be obtained using "fopen"
    # or can correspond to the common "stdout" or "stderr" --
    # available when including stdlib.h
    AA_LOG_STDOUT = 1
    AA_LOG_STDERR = 2
    def aa_log (aardvark, level, handle):
        """usage: int return = aa_log(Aardvark aardvark, int level, int handle)"""
        # Call API function
        return api.py_aa_log(aardvark, level, handle)
    # Return the version matrix for the device attached to the
    # given handle.  If the handle is 0 or invalid, only the
    # software and required api versions are set.
    def aa_version (aardvark):
        """usage: (int return, AardvarkVersion version) = aa_version(Aardvark aardvark)"""
        # Call API function
        (_ret_, c_version) = api.py_aa_version(aardvark)
        # version post-processing
        (version.software, version.firmware, version.hardware, version.sw_req_by_fw, version.fw_req_by_sw, version.api_req_by_sw) = c_version
        return (_ret_, version)
    # Configure the device by enabling/disabling I2C, SPI, and
    # GPIO functions.
    # enum AardvarkConfig
    AA_CONFIG_GPIO_ONLY = 0x00
    AA_CONFIG_SPI_GPIO  = 0x01
    AA_CONFIG_GPIO_I2C  = 0x02
    AA_CONFIG_SPI_I2C   = 0x03
    AA_CONFIG_QUERY     = 0x80
    AA_CONFIG_SPI_MASK = 0x00000001
    AA_CONFIG_I2C_MASK = 0x00000002
    def aa_configure (aardvark, config):
        """usage: int return = aa_configure(Aardvark aardvark, AardvarkConfig config)"""
        # Call API function
        return api.py_aa_configure(aardvark, config)
    # Configure the target power pins.
    # This is only supported on hardware versions >= 2.00
    AA_TARGET_POWER_NONE = 0x00
    AA_TARGET_POWER_BOTH = 0x03
    AA_TARGET_POWER_QUERY = 0x80
    def aa_target_power (aardvark, power_mask):
        """usage: int return = aa_target_power(Aardvark aardvark, u08 power_mask)"""
        # Call API function
        return api.py_aa_target_power(aardvark, power_mask)
    # Sleep for the specified number of milliseconds
    # Accuracy depends on the operating system scheduler
    # Returns the number of milliseconds slept
    def aa_sleep_ms (milliseconds):
        """usage: u32 return = aa_sleep_ms(u32 milliseconds)"""
        # Call API function
        return api.py_aa_sleep_ms(milliseconds)
    # ASYNC MESSAGE POLLING
    # Polling function to check if there are any asynchronous
    # messages pending for processing. The function takes a timeout
    # value in units of milliseconds.  If the timeout is < 0, the
    # function will block until data is received.  If the timeout is 0,
    # the function will perform a non-blocking check.
    AA_ASYNC_NO_DATA = 0x00000000
    AA_ASYNC_I2C_READ = 0x00000001
    AA_ASYNC_I2C_WRITE = 0x00000002
    AA_ASYNC_SPI = 0x00000004
    AA_ASYNC_I2C_MONITOR = 0x00000008
    def aa_async_poll (aardvark, timeout):
        """usage: int return = aa_async_poll(Aardvark aardvark, int timeout)"""
        # Call API function
        return api.py_aa_async_poll(aardvark, timeout)
    # I2C API
    # Free the I2C bus.
    def aa_i2c_free_bus (aardvark):
        """usage: int return = aa_i2c_free_bus(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_i2c_free_bus(aardvark)
    # Set the I2C bit rate in kilohertz.  If a zero is passed as the
    # bitrate, the bitrate is unchanged and the current bitrate is
    # returned.
    def aa_i2c_bitrate (aardvark, bitrate_khz):
        """usage: int return = aa_i2c_bitrate(Aardvark aardvark, int bitrate_khz)"""
        # Call API function
        return api.py_aa_i2c_bitrate(aardvark, bitrate_khz)
    # Set the bus lock timeout.  If a zero is passed as the timeout,
    # the timeout is unchanged and the current timeout is returned.
    def aa_i2c_bus_timeout (aardvark, timeout_ms):
        """usage: int return = aa_i2c_bus_timeout(Aardvark aardvark, u16 timeout_ms)"""
        # Call API function
        return api.py_aa_i2c_bus_timeout(aardvark, timeout_ms)
    # enum AardvarkI2cFlags
    AA_I2C_NO_FLAGS          = 0x00
    AA_I2C_10_BIT_ADDR       = 0x01
    AA_I2C_COMBINED_FMT      = 0x02
    AA_I2C_NO_STOP           = 0x04
    AA_I2C_SIZED_READ        = 0x10
    AA_I2C_SIZED_READ_EXTRA1 = 0x20
    # Read a stream of bytes from the I2C slave device.
    def aa_i2c_read (aardvark, slave_addr, flags, data_in):
        """usage: (int return, u08[] data_in) = aa_i2c_read(Aardvark aardvark, u16 slave_addr, AardvarkI2cFlags flags, u08[] data_in)
        function.
        returned tuple."""
        # data_in pre-processing
        __data_in = isinstance(data_in, int)
        if __data_in:
            (data_in, num_bytes) = (array_u08(data_in), data_in)
        else:
            (data_in, num_bytes) = isinstance(data_in, ArrayType) and (data_in, len(data_in)) or (data_in[0], min(len(data_in[0]), int(data_in[1])))
            if data_in.typecode != 'B':
                raise TypeError("type for 'data_in' must be array('B')")
        # Call API function
        (_ret_) = api.py_aa_i2c_read(aardvark, slave_addr, flags, num_bytes, data_in)
        # data_in post-processing
        if __data_in: del data_in[max(0, min(_ret_, len(data_in))):]
        return (_ret_, data_in)
    # enum AardvarkI2cStatus
    AA_I2C_STATUS_OK            = 0
    AA_I2C_STATUS_BUS_ERROR     = 1
    AA_I2C_STATUS_SLA_ACK       = 2
    AA_I2C_STATUS_SLA_NACK      = 3
    AA_I2C_STATUS_DATA_NACK     = 4
    AA_I2C_STATUS_ARB_LOST      = 5
    AA_I2C_STATUS_BUS_LOCKED    = 6
    AA_I2C_STATUS_LAST_DATA_ACK = 7
    # This API function returns the number of bytes read into
    # the num_read variable.  The return value of the function
    # is a status code.
    def aa_i2c_read_ext (aardvark, slave_addr, flags, data_in):
        """usage: (int return, u08[] data_in, u16 num_read) = aa_i2c_read_ext(Aardvark aardvark, u16 slave_addr, AardvarkI2cFlags flags, u08[] data_in)
        function.
        returned tuple."""
        if __data_in:
        else:
        # Call API function
        (_ret_, num_read) = api.py_aa_i2c_read_ext(aardvark, slave_addr, flags, num_bytes, data_in)
        if __data_in: del data_in[max(0, min(num_read, len(data_in))):]
        return (_ret_, data_in, num_read)
    # Write a stream of bytes to the I2C slave device.
    def aa_i2c_write (aardvark, slave_addr, flags, data_out):
        """usage: int return = aa_i2c_write(Aardvark aardvark, u16 slave_addr, AardvarkI2cFlags flags, u08[] data_out)
        function."""
        # data_out pre-processing
        (data_out, num_bytes) = isinstance(data_out, ArrayType) and (data_out, len(data_out)) or (data_out[0], min(len(data_out[0]), int(data_out[1])))
        if data_out.typecode != 'B':
            raise TypeError("type for 'data_out' must be array('B')")
        # Call API function
        return api.py_aa_i2c_write(aardvark, slave_addr, flags, num_bytes, data_out)
    # This API function returns the number of bytes written into
    # the num_written variable.  The return value of the function
    # is a status code.
    def aa_i2c_write_ext (aardvark, slave_addr, flags, data_out):
        """usage: (int return, u16 num_written) = aa_i2c_write_ext(Aardvark aardvark, u16 slave_addr, AardvarkI2cFlags flags, u08[] data_out)
        function."""
        # Call API function
        return api.py_aa_i2c_write_ext(aardvark, slave_addr, flags, num_bytes, data_out)
    # Do an atomic write+read to an I2C slave device by first
    # writing a stream of bytes to the I2C slave device and then
    # reading a stream of bytes back from the same slave device.
    # the num_written variable and the number of bytes read into
    # the num_read variable.  The return value of the function is
    # the status given as (read_status << 8) | (write_status).
    def aa_i2c_write_read (aardvark, slave_addr, flags, out_data, in_data):
        """usage: (int return, u16 num_written, u08[] in_data, u16 num_read) = aa_i2c_write_read(Aardvark aardvark, u16 slave_addr, AardvarkI2cFlags flags, u08[] out_data, u08[] in_data)
        function.
        returned tuple."""
        # out_data pre-processing
        (out_data, out_num_bytes) = isinstance(out_data, ArrayType) and (out_data, len(out_data)) or (out_data[0], min(len(out_data[0]), int(out_data[1])))
        if out_data.typecode != 'B':
            raise TypeError("type for 'out_data' must be array('B')")
        # in_data pre-processing
        __in_data = isinstance(in_data, int)
        if __in_data:
            (in_data, in_num_bytes) = (array_u08(in_data), in_data)
        else:
            (in_data, in_num_bytes) = isinstance(in_data, ArrayType) and (in_data, len(in_data)) or (in_data[0], min(len(in_data[0]), int(in_data[1])))
            if in_data.typecode != 'B':
                raise TypeError("type for 'in_data' must be array('B')")
        # Call API function
        (_ret_, num_written, num_read) = api.py_aa_i2c_write_read(aardvark, slave_addr, flags, out_num_bytes, out_data, in_num_bytes, in_data)
        # in_data post-processing
        if __in_data: del in_data[max(0, min(num_read, len(in_data))):]
        return (_ret_, num_written, in_data, num_read)
    # Enable/Disable the Aardvark as an I2C slave device
    def aa_i2c_slave_enable (aardvark, addr, maxTxBytes, maxRxBytes):
        """usage: int return = aa_i2c_slave_enable(Aardvark aardvark, u08 addr, u16 maxTxBytes, u16 maxRxBytes)"""
        # Call API function
        return api.py_aa_i2c_slave_enable(aardvark, addr, maxTxBytes, maxRxBytes)
    def aa_i2c_slave_disable (aardvark):
        """usage: int return = aa_i2c_slave_disable(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_i2c_slave_disable(aardvark)
    # Set the slave response in the event the Aardvark is put
    # into slave mode and contacted by a Master.
    def aa_i2c_slave_set_response (aardvark, data_out):
        """usage: int return = aa_i2c_slave_set_response(Aardvark aardvark, u08[] data_out)
        function."""
        # Call API function
        return api.py_aa_i2c_slave_set_response(aardvark, num_bytes, data_out)
    # Return number of bytes written from a previous
    # Aardvark->I2C_master transmission.  Since the transmission is
    # happening asynchronously with respect to the PC host
    # software, there could be responses queued up from many
    # previous write transactions.
    def aa_i2c_slave_write_stats (aardvark):
        """usage: int return = aa_i2c_slave_write_stats(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_i2c_slave_write_stats(aardvark)
    # Read the bytes from an I2C slave reception
    def aa_i2c_slave_read (aardvark, data_in):
        """usage: (int return, u08 addr, u08[] data_in) = aa_i2c_slave_read(Aardvark aardvark, u08[] data_in)
        function.
        returned tuple."""
        if __data_in:
        else:
        # Call API function
        (_ret_, addr) = api.py_aa_i2c_slave_read(aardvark, num_bytes, data_in)
        return (_ret_, addr, data_in)
    # Extended functions that return status code
    def aa_i2c_slave_write_stats_ext (aardvark):
        """usage: (int return, u16 num_written) = aa_i2c_slave_write_stats_ext(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_i2c_slave_write_stats_ext(aardvark)
    def aa_i2c_slave_read_ext (aardvark, data_in):
        """usage: (int return, u08 addr, u08[] data_in, u16 num_read) = aa_i2c_slave_read_ext(Aardvark aardvark, u08[] data_in)
        function.
        returned tuple."""
        if __data_in:
        else:
        # Call API function
        (_ret_, addr, num_read) = api.py_aa_i2c_slave_read_ext(aardvark, num_bytes, data_in)
        return (_ret_, addr, data_in, num_read)
    # Enable the I2C bus monitor
    # This disables all other functions on the Aardvark adapter
    def aa_i2c_monitor_enable (aardvark):
        """usage: int return = aa_i2c_monitor_enable(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_i2c_monitor_enable(aardvark)
    # Disable the I2C bus monitor
    def aa_i2c_monitor_disable (aardvark):
        """usage: int return = aa_i2c_monitor_disable(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_i2c_monitor_disable(aardvark)
    # Read the data collected by the bus monitor
    AA_I2C_MONITOR_DATA = 0x00ff
    AA_I2C_MONITOR_NACK = 0x0100
    AA_I2C_MONITOR_CMD_START = 0xff00
    AA_I2C_MONITOR_CMD_STOP = 0xff01
    def aa_i2c_monitor_read (aardvark, data):
        """usage: (int return, u16[] data) = aa_i2c_monitor_read(Aardvark aardvark, u16[] data)
        function.
        returned tuple."""
        # data pre-processing
        __data = isinstance(data, int)
        if __data:
            (data, num_bytes) = (array_u16(data), data)
        else:
            (data, num_bytes) = isinstance(data, ArrayType) and (data, len(data)) or (data[0], min(len(data[0]), int(data[1])))
            if data.typecode != 'H':
                raise TypeError("type for 'data' must be array('H')")
        # Call API function
        (_ret_) = api.py_aa_i2c_monitor_read(aardvark, num_bytes, data)
        # data post-processing
        if __data: del data[max(0, min(_ret_, len(data))):]
        return (_ret_, data)
    # Configure the I2C pullup resistors.
    AA_I2C_PULLUP_NONE = 0x00
    AA_I2C_PULLUP_BOTH = 0x03
    AA_I2C_PULLUP_QUERY = 0x80
    def aa_i2c_pullup (aardvark, pullup_mask):
        """usage: int return = aa_i2c_pullup(Aardvark aardvark, u08 pullup_mask)"""
        # Call API function
        return api.py_aa_i2c_pullup(aardvark, pullup_mask)
    # SPI API
    # Set the SPI bit rate in kilohertz.  If a zero is passed as the
    # returned.
    def aa_spi_bitrate (aardvark, bitrate_khz):
        """usage: int return = aa_spi_bitrate(Aardvark aardvark, int bitrate_khz)"""
        # Call API function
        return api.py_aa_spi_bitrate(aardvark, bitrate_khz)
    # These configuration parameters specify how to clock the
    # bits that are sent and received on the Aardvark SPI
    # interface.
    #   The polarity option specifies which transition
    #   constitutes the leading edge and which transition is the
    #   falling edge.  For example, AA_SPI_POL_RISING_FALLING
    #   would configure the SPI to idle the SCK clock line low.
    #   The clock would then transition low-to-high on the
    #   leading edge and high-to-low on the trailing edge.
    #   The phase option determines whether to sample or setup on
    #   the leading edge.  For example, AA_SPI_PHASE_SAMPLE_SETUP
    #   would configure the SPI to sample on the leading edge and
    #   setup on the trailing edge.
    #   The bitorder option is used to indicate whether LSB or
    #   MSB is shifted first.
    # See the diagrams in the Aardvark datasheet for
    # more details.
    # enum AardvarkSpiPolarity
    AA_SPI_POL_RISING_FALLING = 0
    AA_SPI_POL_FALLING_RISING = 1
    # enum AardvarkSpiPhase
    AA_SPI_PHASE_SAMPLE_SETUP = 0
    AA_SPI_PHASE_SETUP_SAMPLE = 1
    # enum AardvarkSpiBitorder
    AA_SPI_BITORDER_MSB = 0
    AA_SPI_BITORDER_LSB = 1
    # Configure the SPI master or slave interface
    def aa_spi_configure (aardvark, polarity, phase, bitorder):
        """usage: int return = aa_spi_configure(Aardvark aardvark, AardvarkSpiPolarity polarity, AardvarkSpiPhase phase, AardvarkSpiBitorder bitorder)"""
        # Call API function
        return api.py_aa_spi_configure(aardvark, polarity, phase, bitorder)
    # Write a stream of bytes to the downstream SPI slave device.
    def aa_spi_write (aardvark, data_out, data_in):
        """usage: (int return, u08[] data_in) = aa_spi_write(Aardvark aardvark, u08[] data_out, u08[] data_in)
        function.
        returned tuple."""
        (data_out, out_num_bytes) = isinstance(data_out, ArrayType) and (data_out, len(data_out)) or (data_out[0], min(len(data_out[0]), int(data_out[1])))
        if __data_in:
            (data_in, in_num_bytes) = (array_u08(data_in), data_in)
        else:
            (data_in, in_num_bytes) = isinstance(data_in, ArrayType) and (data_in, len(data_in)) or (data_in[0], min(len(data_in[0]), int(data_in[1])))
        # Call API function
        (_ret_) = api.py_aa_spi_write(aardvark, out_num_bytes, data_out, in_num_bytes, data_in)
    # Enable/Disable the Aardvark as an SPI slave device
    def aa_spi_slave_enable (aardvark):
        """usage: int return = aa_spi_slave_enable(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_spi_slave_enable(aardvark)
    def aa_spi_slave_disable (aardvark):
        """usage: int return = aa_spi_slave_disable(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_spi_slave_disable(aardvark)
    def aa_spi_slave_set_response (aardvark, data_out):
        """usage: int return = aa_spi_slave_set_response(Aardvark aardvark, u08[] data_out)
        function."""
        # Call API function
        return api.py_aa_spi_slave_set_response(aardvark, num_bytes, data_out)
    # Read the bytes from an SPI slave reception
    def aa_spi_slave_read (aardvark, data_in):
        """usage: (int return, u08[] data_in) = aa_spi_slave_read(Aardvark aardvark, u08[] data_in)
        function.
        returned tuple."""
        if __data_in:
        else:
        # Call API function
        (_ret_) = api.py_aa_spi_slave_read(aardvark, num_bytes, data_in)
    # Change the output polarity on the SS line.
    # Note: When configured as an SPI slave, the Aardvark will
    # always be setup with SS as active low.  Hence this function
    # only affects the SPI master functions on the Aardvark.
    # enum AardvarkSpiSSPolarity
    AA_SPI_SS_ACTIVE_LOW  = 0
    AA_SPI_SS_ACTIVE_HIGH = 1
    def aa_spi_master_ss_polarity (aardvark, polarity):
        """usage: int return = aa_spi_master_ss_polarity(Aardvark aardvark, AardvarkSpiSSPolarity polarity)"""
        # Call API function
        return api.py_aa_spi_master_ss_polarity(aardvark, polarity)
    # GPIO API
    # The following enumerated type maps the named lines on the
    # Aardvark I2C/SPI line to bit positions in the GPIO API.
    # All GPIO API functions will index these lines through an
    # 8-bit masked value.  Thus, each bit position in the mask
    # can be referred back its corresponding line through the
    # enumerated type.
    # enum AardvarkGpioBits
    AA_GPIO_SCL  = 0x01
    AA_GPIO_SDA  = 0x02
    AA_GPIO_MISO = 0x04
    AA_GPIO_SCK  = 0x08
    AA_GPIO_MOSI = 0x10
    AA_GPIO_SS   = 0x20
    # Configure the GPIO, specifying the direction of each bit.
    # A call to this function will not change the value of the pullup
    # mask in the Aardvark.  This is illustrated by the following
    # example:
    #   (1) Direction mask is first set to 0x00
    #   (2) Pullup is set to 0x01
    #   (3) Direction mask is set to 0x01
    #   (4) Direction mask is later set back to 0x00.
    # The pullup will be active after (4).
    # On Aardvark power-up, the default value of the direction
    # mask is 0x00.
    AA_GPIO_DIR_INPUT = 0
    AA_GPIO_DIR_OUTPUT = 1
    def aa_gpio_direction (aardvark, direction_mask):
        """usage: int return = aa_gpio_direction(Aardvark aardvark, u08 direction_mask)"""
        # Call API function
        return api.py_aa_gpio_direction(aardvark, direction_mask)
    # Enable an internal pullup on any of the GPIO input lines.
    # Note: If a line is configured as an output, the pullup bit
    # for that line will be ignored, though that pullup bit will
    # be cached in case the line is later configured as an input.
    # By default the pullup mask is 0x00.
    AA_GPIO_PULLUP_OFF = 0
    AA_GPIO_PULLUP_ON = 1
    def aa_gpio_pullup (aardvark, pullup_mask):
        """usage: int return = aa_gpio_pullup(Aardvark aardvark, u08 pullup_mask)"""
        # Call API function
        return api.py_aa_gpio_pullup(aardvark, pullup_mask)
    # Read the current digital values on the GPIO input lines.
    # The bits will be ordered as described by AA_GPIO_BITS.  If a
    # line is configured as an output, its corresponding bit
    # position in the mask will be undefined.
    def aa_gpio_get (aardvark):
        """usage: int return = aa_gpio_get(Aardvark aardvark)"""
        # Call API function
        return api.py_aa_gpio_get(aardvark)
    # Set the outputs on the GPIO lines.
    # Note: If a line is configured as an input, it will not be
    # affected by this call, but the output value for that line
    # will be cached in the event that the line is later
    # configured as an output.
    def aa_gpio_set (aardvark, value):
        """usage: int return = aa_gpio_set(Aardvark aardvark, u08 value)"""
        # Call API function
        return api.py_aa_gpio_set(aardvark, value)
    # Block until there is a change on the GPIO input lines.
    # Pins configured as outputs will be ignored.
    # The function will return either when a change has occurred or
    # the timeout expires.  The timeout, specified in millisecods, has
    # a precision of ~16 ms. The maximum allowable timeout is
    # approximately 4 seconds. If the timeout expires, this function
    # will return the current state of the GPIO lines.
    # This function will return immediately with the current value
    # of the GPIO lines for the first invocation after any of the
    # following functions are called: aa_configure,
    # aa_gpio_direction, or aa_gpio_pullup.
    # If the function aa_gpio_get is called before calling
    # aa_gpio_change, aa_gpio_change will only register any changes
    # from the value last returned by aa_gpio_get.
    def aa_gpio_change (aardvark, timeout):
        """usage: int return = aa_gpio_change(Aardvark aardvark, u16 timeout)"""
        # Call API function
        return api.py_aa_gpio_change(aardvark, timeout)
    aardvark_rw.py
    #!/bin/env python
    # -*- coding: cp1252 -*-
    # (c) 2015 Texas Instruments
    # Project : Method and parameters for hardware interface adaptations
    # File    : aardvark_rw.py
    # Redistribution and use of this file in source and binary forms, with
    # or without modification, are permitted.
    # IMPORTS
    import sys
    from aardvark_py import *
    # CONSTANTS
    BUS_TIMEOUT = 150  # ms
    # GLOBALS
    # FUNCTIONS
    def init_aardvark(port, bitrate, spibitrate):
        myException = Exception()
        handle = aa_open(port)
        if (handle <= 0):
            myException.message = "Unable to open Aardvark device on port %d\n" % port
            myException.message += "Error code = %d" % handle
            raise myException
        # Ensure that the I2C subsystem is enabled
        aa_configure(handle,  AA_CONFIG_SPI_I2C)
        # Enable the I2C bus pullup resistors (2.2k resistors).
        # This command is only effective on v2.0 hardware or greater.
        # The pullup resistors on the v1.02 hardware are enabled by default.
        aa_i2c_pullup(handle, AA_I2C_PULLUP_BOTH)
        # Power the EEPROM using the Aardvark adapter's power supply.
        # The power pins on the v1.02 hardware are not enabled by default.
        aa_target_power(handle, AA_TARGET_POWER_BOTH)
        # Set the bitrate
        bitrate = aa_i2c_bitrate(handle, bitrate)
        print "I2C Bitrate set to %d kHz" % bitrate
        bus_timeout = aa_i2c_bus_timeout(handle, BUS_TIMEOUT)
        print "I2C Bus lock timeout set to %d ms" % bus_timeout
        # configure spi
        aa_spi_configure(handle, 0, 0, AA_SPI_BITORDER_MSB)
        # Set the bitrate to 20 MHz
        bitrate = aa_spi_bitrate(handle, spibitrate)
        print "SPI Bitrate set to %d kHz" % spibitrate
        return handle
    # main
    if __name__ == "__main__":
        print "This file contains Aardvark related helper functions and is not"
        print "intended to be run stand alone. To use, import constituent functions"
        print "into a script or python environment using:"
        print "from aardvark_rw import *"
        sys.exit()
    aardvark_spi.py
    #!/bin/env python
    # (c) 2004  Total Phase, Inc.
    # Project : Aardvark Sample Code
    # File    : aaspi_eeprom.py
    # Perform simple read and write operations to an SPI EEPROM device.
    # IMPORTS
    import sys
    import time
    SPI_PAGE_SIZE = 256
    # CONSTANTS
    FLASH_COMMAND_WRITE_ENABLE               = 0x06
    FLASH_COMMAND_WRITE_ENABLE_STATUS        = 0x50
    FLASH_COMMAND_WRITE_DISABLE              = 0x04
    FLASH_COMMAND_READ_STATUS                = 0x05
    FLASH_COMMAND_WRITE_STATUS               = 0x01
    # READ_DATA requires SPI CLK < 33 MHz
    FLASH_COMMAND_READ_DATA                  = 0x03
    # FAST_READ supports 50 MHz clock
    FLASH_COMMAND_FAST_READ                  = 0x0B
    FLASH_COMMAND_FAST_READ_DUAL_OUTPUT      = 0x3B
    FLASH_COMMAND_FAST_READ_DUAL_IO          = 0xBB
    FLASH_COMMAND_PAGE_PROGRAM               = 0x02
    FLASH_COMMAND_SECTOR_ERASE               = 0x20
    FLASH_COMMAND_BLOCK_ERASE_32K            = 0x52
    FLASH_COMMAND_BLOCK_ERASE_64K            = 0xD8
    FLASH_COMMAND_CHIP_ERASE                 = 0xC7
    FLASH_COMMAND_POWER_DOWN                 = 0xB9
    FLASH_COMMAND_RELEASE_POWER_DOWN         = 0xAB
    # FUNCTIONS
    def byteArray(n):
        strArray = bin(n)[2:].zfill(8*((len(bin(n)[2:])-1) / 8) + 8)
        ret = array('B')
        for i in range(len(strArray)/8):
            if i != 0:
                ret.append(int(strArray[-i*8-8:-i*8],2))
            else:
                ret.append(int(strArray[-8:],2))
        return ret
    # w25q80 uses 8-bit command followed by 3-byte address
    # data out is what you write
    # data in is what you read
    def spi_write(handle, cmd, addr, data_out, data_in):
        data_send = array('B', [ cmd ])
        revArray = byteArray(addr)
        for i in range(3-len(byteArray(addr))):
            revArray.append(0)
        for i in range(3):
            data_send.append(revArray[2-i])
        data_send.extend(data_out)
        data_receive = array('B', [0,0,0,0])
        data_receive.extend(data_in)
        return aa_spi_write(handle, data_send, data_receive)
    def aa_spi_writeMemory (handle, addr, data_in):
        # Write to the SPI FLASH
        # Send write enable command
        data_out = array('B', [ FLASH_COMMAND_WRITE_ENABLE ])
        # aa_spi_write(handle, array_in, array_out)
        #    arrays may be replaced by an integer specifying length
        aa_spi_write(handle, data_out, array('B',[]))
        aa_sleep_ms(10)
        # Assemble write command and address
        data_out = array('B', [ 0 for i in range(SPI_PAGE_SIZE) ])
        # Assemble a page of data
        for i in range(min(SPI_PAGE_SIZE, len(data_in))):
            data_out[i] = data_in[i]
        # Truncate the array to the exact data size
        del data_out[i+1:]
        # Write the transaction
        spi_write(handle, FLASH_COMMAND_PAGE_PROGRAM, addr, data_out, data_in)
        aa_sleep_ms(10)
        # Wait until data page is written
        flash_block_busy(handle)
        if(len(data_in) > SPI_PAGE_SIZE):
            print 'SPI Write attempt of block size greater than page size of %d' %SPI_PAGE_SIZE
            sys.exit()
        if(((addr + len(data_in) - 1) & 0xFFFFFF00) != (addr & 0xFFFFFF00)):
            print 'SPI Write attempt wraps past page boundary. This causes unpredicatble write behavior.'
            sys.exit()
    def aa_spi_readMemory (handle, addr, length):
        data_in = array('B', [ 0 for i in range(length) ])
        data_out = array('B', [ 0 for i in range(length) ])
        # Write length empty bytes to drive SPI clk for read
        (count, data_in) = spi_write(handle, FLASH_COMMAND_READ_DATA, addr, data_out, data_in)
        if (count < 0):
            print "error: %s\n" % aa_status_string(count)
            return
        elif (count != length+4):
            print "error: read %d bytes (expected %d)" % (count-4, length)
        return (count-4, data_in[4:])
    def flash_block_busy(handle):
        data_out = array('B', [FLASH_COMMAND_READ_STATUS, 0])
        data_in = array('B', [0,0])
        (count, data_in) = aa_spi_write(handle, data_out, data_in)
        while(data_in[1] & 0x1):
        # 0 = success
        return 0
    def aa_flash_sector_erase_spi(handle, addr, numSector):
        address = addr & 0xFFFFF000
        # Erase Sectors
        # no data, so make dummy array of len zero
        dummy = array('B', [])
        for i in range(numSector):
            # have to write enable before each erase command
            aa_sleep_ms(10)
            spi_write(handle, FLASH_COMMAND_SECTOR_ERASE, address, dummy, dummy)
            address += 0x1000
            aa_sleep_ms(10)
    # MAIN PROGRAM
        print 'This file is a helper file for programming SPI flash'
        print 'It should be imported into a python environment or another script'
        print 'using:'
        print 'from aardvark_spi import *'
        sys.exit()
  • Hi Brian-san,
    I tried to copy your files however the following error occured.
    Then, I tried to access TotalPhase Aardvark Software Download Page and download software of Windows-32bit.
    http://www.totalphase.com/products/aardvark-software-api/
    I got aardvark.dll and aardvark_py.py and replaced them but the following error occured..
    How should I confirm next?
    Yaita
  • Hi Brian-san,
    I apologize I mistaked the following connection..
    I achieved to access registers of TPS65986 with Aardvark(I2C).
    I really appreciated for your continuous support!
    Yaita
