Quickly find solutions to common questions about transformer drivers by clicking this link. This FAQ answers the most common questions asked about these devices …… ……… …
FAQ: Isolation >> Transformer Drivers
| Digital Isolators | Isolated Interfaces | Transformer Drivers | |
- [FAQ] Whey are D1 and D2 pins of SN650x push-pull transformer driver shorted to GND?
- [FAQ] What primary inductance value should I choose for my push-pull power supply design using SN650x devices?
- [FAQ] How do you generate power for an isolated RS-485 node?
- [FAQ] SN6505B-Q1: Driving waveform distortion at high ambient temperature.
- [FAQ] Which diodes should be used when using a transformer driver?
- [FAQ] What is the push-pull topology and how is it different from other isolated power architectures?
- [FAQ] How can you choose a transformer for your system?
- [FAQ] Why use transformer drivers over other solutions?
- [FAQ] Can you step down voltage in a transformer driver system?
- [FAQ] Where is the isolation barrier located in a transformer based power supply?
