LSF0204: Pull-high resistance design for LSF0204
Part Number: LSF0204
Hi team,
For LSF0204, could you help to confirm what's the internal connection / block diagram when config the device in to push-pull or OD respectively?
For example, if we set the device into OD, then do we need to consider internal pull-high resistance? If we set the device to push-pull, how large internal pull high resistance customer should consider?
Max
