Part Number: SN7400
Need the ioh(min) and iih(min) values of the following parameter. its not available in datasheet.
1. SN7406DR-5V supply
2. SN74F38DR-5V supply
3.TPS386596L33DGKR- 3.3V supply
All these devices have open-collector/open-drain outputs, so specifying IOH would not make sense. If you need a high-level voltage, then you have a pull-up resistor, and the current is determined by that.
IIH(max) is the worst-case leakage current that your circuit must be able to handle. IIH(min), the best-case leakage current, is not specified because it's zero (or small enough that it does not matter).
