Part Number: SN74AVC8T245
Please tell me about the following. I would appreciate it if you could give me an answer as soon as possible.
・Does the SN74AVC8T245 have power sequence requirements? Please tell me if there is.
・What kind of problems can be expected when the OE pin is connected to GND while VCCA is on?
・If both the power supply VCCA and VCCB are 0V, is it okay if a signal enters the OE, A port, or B port ? Will there be unexpected logical values or failures ?
・I would like to know if there is no problem even if only VCCA is powered on for a long time. There is no sequence requirement, but will only VCCA fail if the power is on for a long time?
・Is it possible to switch directions dynamically? Please tell me the procedure if possible.
