Part Number: TXU0104
TXU0104 datasheet paragraph 9.3.5 specifies that "... It is
recommended that the inputs are kept low before floating (disconnecting) either supply..."
What does this mean?
I interpret the rest of paragraph 9.3.5 to mean that is either the VCCA or VCCB power rails is interrupted (ie. goes down), then the TXU0104 puts its A-Side inputs and B-Side outputs into a high-Z state thereby essentially disconnecting itself from the rest of the surrounding electronic circuit. This is perfect for my application.
I am however not sure what to make of the statement identified above. If by "floating (disconnecting) either supply" you mean power goes off in either supply, then I question whether or not I have a problem... I am not monitoring VCCA or VCCB power rails so cannot anticipate if and when power in either goes down; hence do not have time to put the TXU0104 inputs in a logic-low state.
Please advise how the TXU0104 behaves with random (ie. unpredictable) VCCA or VCCB power rail failures.
Cheers, B Banik
