Other Parts Discussed in Thread: TXS0104E, TXU0304-Q1
Hi team,
My customer want to use TXS0104E OE pin to achieve signal selection function, schematic is as below. Could you kindly help double check? Appreciate for your help!
BR
Jiawei
Hi team,
BR
Jiawei
Hey Jiawei,
I recommend they use the TXU0304-Q1 device for this. It shares the same pinout, but the channels are fixed direction. TXS does not work well with heavy capacitive loads and should not be used with pull-downs. TXU will have strong buffered outputs and schmitt-trigger inputs making it ideal for this. Its OE pin can also be operated in the same way with one device being enabled at a time.
