Part Number: TXS0104E
Currently we are using TXS0104EPWR (4-BIT) part in our design for converting voltage level from 1V8 to 3V3.We are using this for MDIO and MDC pin of Ethernet PHY.
With this part we are facing IO level mismatch between CPU pins and Level Translator pins.
Could you please suggest a 4-bit translator part which supports MDC and MDIO pin ( Open-drain).Also the translator should have VIH > 1.35 AND VIL > 0.45.
Attached the block diagram of the same.
Nireeksha
