Part Number: LSF0102
Other Parts Discussed in Thread: SN74AXC1T45
If one of the signals is push pull, do we still need a pull up resistor? For instance, a 1.8V push pull clock needs to transfer to 2.5V, do we need a pull up resistor on 2.5v side?
Yes.
Please see this video for a detailed description of how up-translation works in the LSF family of translators: Up Translation with the LSF Family
I would recommend to go ahead and watch the whole series if you're working on a project that includes the LSF - it's a good idea to understand the basics of how this device works as it's probably not exactly what you'd expect.
As an added note - if a clock signal needs to be changed from 1.8V to 2.5V, I would _not_ recommend using LSF. An active translator like SN74AXC1T45 would be a much better choice. I would only recommend to use LSF in the case where a data signal changes directions without any control signal.
