SN74LVC1G11-EP: Thermal Resistance
Part Number: SN74LVC1G11-EP
I am using SN74LVC1G11MDCKREP gate in my design. I need junction to case resistance information for the IC.
From datasheet I got junction to ambient resistance. Is there any information available on thermal resistance for IC on TI site?
Namita
  • Hi Namita,
    Here are the thermal values for this device.
    Result- Theta JA-High K (standard datasheet value) 213.2
    Result-Theta JC, top (standard datasheet value) 146.8
    Result-Theta JB (standard datasheet value) 61.7
    Result- Psi JT (standard datasheet value) 45.4
    Result- Psi JB (standard datasheet value) 61.4
    Result-Theta JC, bottom (standard datasheet value) n/a
  • Hi Albert,
    Thank you for the information provided.
    Can you please also provide junction to case thermal resistance values for the part listed below.
    PART NUMBER Rth(jc) (oC/W)
    SN74LVC2G34DCKR
    SN74LVC244APW
    SN74LVC1G17QDCKRQ1
    SM320F2812PGFMEP
    TPS75433QPWP
    TPS75418QPWP
    TPS3306-18QDRQ1
    SN74LVC1G14MDBVREP
    SN74LVC1G08MDBVREP
    INA293A2QDBVRQ1
    REF2025AISDDCR
    SN74LVC1T45MDCKREP
    OPA2192QDGKRQ1
    OPA192IDBVT
    TLE2062MD
    REF2030AIDDCT
    Namita
  • Hi Namita,
    Some of these parts aren't ours (Logic and Voltage Translation). I recommend to go ask the respective groups for those. I can provide you with the data values for our devices.
    SN74LVC2G34DCKR
    Result- Theta JA-High K (standard datasheet value) 250.2
    Result-Theta JC, top (standard datasheet value) 86.8
    Result-Theta JB (standard datasheet value) 53.6
    Result- Psi JT (standard datasheet value) 1.5
    Result- Psi JB (standard datasheet value) 53.0
    SN74LVC244APW
    Result- Theta JA-High K (standard datasheet value) 114.7
    Result-Theta JC, top (standard datasheet value) 48.4
    Result-Theta JB (standard datasheet value) 65.6
    Result- Psi JT (standard datasheet value) 6.8
    Result- Psi JB (standard datasheet value) 65.1
    SN74LVC1G17QDCKRQ1
    Result- Theta JA-High K (standard datasheet value) 290.1
    Result-Theta JC, top (standard datasheet value) 100.7
    Result-Theta JB (standard datasheet value) 67.6
    Result- Psi JT (standard datasheet value) 2.1
    Result- Psi JB (standard datasheet value) 66.9
    SN74LVC1G14MDBVREP
    Result- Theta JA-High K (standard datasheet value) 272.7
    Result-Theta JC, top (standard datasheet value) 214.9
    Result-Theta JB (standard datasheet value) 109.7
    Result- Psi JT (standard datasheet value) 90.9
    Result- Psi JB (standard datasheet value) 109.1
    SN74LVC1G08MDBVREP
    Result- Theta JA-High K (standard datasheet value) 224.4
    Result-Theta JC, top (standard datasheet value) 181.7
    Result-Theta JB (standard datasheet value) 59.2
    Result- Psi JT (standard datasheet value) 59.3
    Result- Psi JB (standard datasheet value) 58.7
    SN74LVC1T45MDCKREP
    Result- Theta JA-High K (standard datasheet value) 203.4
    Result-Theta JC, top (standard datasheet value) 139.2
    Result-Theta JB (standard datasheet value) 53.3
    Result- Psi JT (standard datasheet value) 38.4
