TXB0304: TXB0304
Part Number: TXB0304
Dear TI team,
I'm using IBIS model in HSPICE and encountering error : "**error** (b_lvlshftd:15) Buffer is power on with voltage source connected to node PU, where File = txb0304.ibs, Model = IO_33_OS"
Seeking for the right way of connection.
Below is the hspice deck with using ibis model,
Thank you,
Yng Yng
.OPTION INGOLD=1 DCON=1 BRIEF=1 NOTOP NOELCK POST=1 *.option itl4=100 reltol=1e-2   abstol=1e-6 gshunt=1e-10  cshunt=1e-11 method=gear
.option NUMDGT=6 *.option finesim_mode=spicemd finesim_print_period=10p finesim_output=tr0
.param data_rate=33e+06 .param tbit='1/data_rate' .param vpat_delay=0.8u
Vdata_in3p3  DATA_IN_3p3 0 pat ( 0 3 'vpat_delay' .1n .1n 'tbit' b1111001010101000000111111101010101010101010101100110011001100110011001100110011001100110011001100110011001100111100001111000011110000111100001111000011110000111100001111000011111110000000111111100000001111111000000011111110000000111111100000001111111000000011111110000000111111100000001111111011111110111111101111111011111110111111101111111011111110100000001000000010000000100000001000000010000000100000001000000010000000100000001011100011000010001010001111111111 )
*B_IO         nd_pu            nd_pd           nd_out          nd_in            nd_en          nd_out_of_in        [nd_pc                  nd_gc] B_lvlshftd  txb0304_13_pu    txb0304_6_pd    txb0304_12_load    DATA_IN_3p3         txb0304_13_pu          txb0304_10_outofin    txb0304_13_pu   txb0304_6_pd + file ='txb0304.ibs' + model = 'IO_33_OS'
V_txb0304_13_pu txb0304_13_pu 0 3.3 V_txb0304_6_pd txb0304_6_pd   0 0
.probe v(txb0304_12_load) .tran 1n 'vpat_delay + 60*tbit' START='vpat_delay'
.end
    The IBIS model is not designed to be used in HSPICE. It is typically used in Hyperlynx or ADS by our customers.
    The IBIS model is designed to test the I/O signal integrity and is not able to simulate any logic functionality.
    Karan
