Can you violate the overshoot and undershoot recommended max voltages if you do not exceed a certain current on this IC?
I know this is pretty typical of IC's and the current spec does not allow a lot of wiggle room for overshoot (rec. max=VCCA/B).
Maybe the real limit is the abs. max, but that also notes permanent damage. Specifically I would be seeing ~200mV overshoot on a 1.8V logic side.
Thank you
