Other Parts Discussed in Thread: TXB0104
I need to use this device for voltage translation on SPI line for 4 slave devices that are all on the same SPI line. Each slave device will have his own SPI buffer TXU0304
However i found strange that OE is active high because usually SPI device chip select is active low.
I don't have any TXU304 device right now so can't test it.
So could you confirm that if my SPI slaves have a /CS, i have to invert the /CS signal before connecting it to the OE of the buffer driver.
