Part Number: TXS0102
I am using a TXS0102 logic level translator in my project. The datasheet says to keep the OE pin (output enable) low until VccA and VccB are applied. Can I simply tie the OE pin to VccA with the benefit of eliminating a control line? If so, can I tie directly to VccA or do I need a resistor in series? If yes on the resistor what value of resistor do you recommend?
HSG
