Part Number: SN74HC74
Other Parts Discussed in Thread: SN74HCS08
We have been using SN74HC74DR for a number of years without issue. Recently our production team started to notice failures in the test jig for one of our boards, caused by timing issues. The code for the test jig was slightly changed to match the boards allowing it to pass but they have been failing when used in a product assembly.
At the moment it seems both working and non working boards have TI part SN74HC74DR fitted. The working boards however have the marking "13A3DGM G4 HC74" on SN74HC74DR while the non working boards have the marking "1AZ3C7JG3 HC74".
I have not been able to find any information on the difference between the markings, perhaps it is different manufacturing locations which also use different materials.
I have also not seen any information regarding any potential differences between the electrical specifications of the parts. If someone could help with identifying potential causes for timing issues between the parts or other important differences that would be great.
Thank you!
Kian
