Other Parts Discussed in Thread: CD4027B, , SN74HCS74, SN74AUP1G80
Dear TI team,
I want to use a master slave JK Flip flop to toggle the output when Clk is generated. A tactile switch will be connected on clk signal to operate it as on/off switch at +ve edge trigger. Output acts as ON when the switch is pressed once, next time the output turns OFF when switch is again pressed. To avoid "racing", I wish to use a master slave JK FF and "CD4027B" is of a kind but the minimum supply voltage in my design is 2.4V. Hence, can you suggest any alternate part?
Moreover, I want to know if I can configure "CD74AC109" as master slave FF as it is a dual FF and I am using only one of it. Need your guidance on how shall I configure it to operate as master slave JK FF.
Vinnie
