Other Parts Discussed in Thread: TPS3421
Hi Team,
Could you please help me with below issue? “TPS3421+SN74AUP3G14” is used in the system to reset the MCU, where SN74AUP3G14 is used to flip the reset signal. The input side of SN74AUP3G14 has a 10k pull-up resistor.
1,How to calculate the static power consumption of the NOT gate itself, is it A+B?
2,In addition, I think it is because there is a voltage difference between the input and the supply voltage of the NOT gate, which leads to the weak conduction of the upper P-MOSFET in the NOT gate, that is, there is a leakage current from VCC to GND. Could you please provide your comments? If this is the reason, how to avoid it?
Thanks and regards,
Hailiang
