Hi Team,
Could you help? Our customer is looking at SN74AVC2T245. It fits their application however they are looking for an "Active High Enable".
SN74AVC2T245 is Active Low Enable. Can you help me a solution for this. Does using an inverter to the OE control signal helps?
Otherwise is there any other part recommended.
Thank you in advance
Jonathan
The only buffers with active-high enable are the four-channel 74xx126 devices.
Use an inverter.
Hey Jonathan,
There are two devices I recommend that can potentially work here - TXU0102 or TXU0202.
