TXB0104: High Current Draw
Part Number: TXB0104
Other Parts Discussed in Thread: TXU0304, TXU0104, TXU0204
Good Day. I have a customer who is working with TXB0104. Please see below his query for your reference. Thank you very much.
I have used TXB0104RUTR on a previous design and didn't have as high of a current draw from the part that I'm seeing on a new design I have. I am seeing that when the translator is enabled and no voltage is applied to any inputs, the current draw is around 250uA when I was seeing almost no current draw before. When I ground the OE signal, the 250uA goes away so I get the feeling it's coming from the part.
Any idea how this could happen? Did anything change with the design recently making it so I don't see this on older boards I have with this part?
The IC consumes about 250uA when VCCB has a higher voltage than VCCA
I have 1.8v on VCCB and 3.3v on VCCA only on one of the translator chips I'm using. The other translator chips have the higher voltage on VCCB and don't have a high current draw.
Ray Vincent
