Part Number: TXS0108E-Q1
Other Parts Discussed in Thread: SN74LXC8T245-Q1, TXU0304-Q1, SN74AXC8T245-Q1, TXU0104-Q1, TXU0204-Q1
Hi team
There is a good new that we DIN TI TXS0108E-Q1!
The end application is Automatic Parking sensor!
Cause the io port on the ECU side is not enough, so need level shift to provide the same voltage.
Following question need your help,
1. What is the design difference between Open-Drain and Push-Pull design ?
2.It seems most of the designers to promote the design of open draina and why not promote push pull?
3.What is the function of the "OE pin" and what should be considered when designing?
