TXS0206AEVM: How to handle the enable pin of TXS0206AEVM
Guru 12815 points
Part Number: TXS0206AEVM
I have a question about the enable pin of the TXS0206AEVM.
The device did not work when the enable pin was shorted to Vcca, but when pulled up with 40kΩ it worked fine.
The datasheet only says HIGH, so could you tell me if this method is the correct way to use it?
Astro
