Part Number: LSF0108
Hi all,
I am using LSF0108 as a level shift between 1.2V to 3.3V, when doing the SI simulation, the output’s voltage is not 3.3V。
Hey Feng,
Welcome to the E2E forums! You are seeing this output because of the 50ohm termination resistor at the output. It is strongly recommended to take this resistor out (the current circuit is acting like a resistor divider).
Jack
Hi Feng,
You are using the wrong type of model. You have to treat the device like a bus switch.
Karan
