Part Number: LSF0204
Other Parts Discussed in Thread: TXB0104, TXB0106, TXB0304
Hi Team,
Can you help with the inquiry below?
1.Can LSF0204 be adopted for level conversion from 1.8V QSPI to 3.3V QSPI? I saw the application implementation in the datasheet and it seems doable. can you confirm?
2.The QSPI of CPU is 1.8V, while the QSPI of FLASH is 3.3V. What level conversion chip should be used? CPU QSPI is 66 MHZ? will the LSF0204 works or can I use TXB0104 or TXB0106?
Looking forward to your response.
Marvin
