Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
[FAQ] SN74HCS00: The Logic Industry's Smallest Leaded Package; DYY
Part Number: SN74HCS00
The Logic Industry’s Smallest Leaded Package; SOT-23-THIN (DYY)
                Many companies still rely solely on optical verification methods to ensure their components have been successfully soldered and are unwilling or not yet able to move to x-ray technology for their manufacturing. With space at a premium, dual sourced supply as a primary concern, and manufacturing compatibility with existing infrastructure set at top priority these companies turn to the logic industry’s smallest leaded package.
SOT-23-THIN (DYY) Size
Alternate Package Size
Total Space Savings
14 pin DYY 8.4mm²
14 pin TSSOP (PW) 22mm²
13.6mm²  (61.8% smaller)
16 pin DYY 8.4mm²
16 pin TSSOP (PW) 22mm²
14 pin DYY 8.4mm²
14 pin SOIC (D) 33.8mm²
25.4mm²  (75.1% smaller)
16 pin DYY 8.4mm²
16 pin SOIC (D) 38.7mm²
30.3mm²  (78.3% smaller)
Figure 1. Package comparison of DYY and other industry standard leaded packages
SOT-23-THIN (DYY) is the logic industry’s smallest leaded package providing many manufacturers a great middle ground solution for addressing manufacturing, supply, as well as PCB design constraints. The DYY package is now being offered by Texas Instruments in a multitude of mainstay logic components such as gates, buffers, and shift registers (offered in both automotive/commercial variants) and is revolutionizing board design.
Figure 2. Example of PW and DYY package dual footprint layout (measured in board space used not overall package size)
The SOT-23-THIN package is an excellent choice for those concerned about ensuring dual sourced supply. This package can be designed into boards with a dual-footprint layout with many of the industry’s most popular package choices. This allows manufacturers to utilize multiple package offerings of the same device without re-designing their PCB providing ultimate design flexibility. For more information about this design methodology and to see if it’s right for you please see Optimizing Board Design for Supply Constrained Environments.
                There are many other benefits to utilizing a small footprint leaded package like SOT-23-THIN (DYY) including but not limited to:
  1. Simplified PCB design
  2. Ability to utilize current manufacturing process/infrastructure with no changes required
  3. Better thermal cycling performance
  4. Price reduction in manufacturing for materials like solder paste compared to leaded package variants
Below are new devices released from TI in SOT-23-THIN (DYY) Packaging.
OPN
Common EEs
Enterprise
Commercial
Personal Electronics
Industrial
SN74HCS74DYYR
Hardware accelerator, Rack/Blade server, High performance computing
Gateway (xDSL/cable), Datacenter switch, Wireless Lan (WLAN), Core/Edge router
Consumer IoT devices, Portable electronics, Data storage
Access control, Condition monitoring sensor, AC indoor unit
SN74HCS00DYYR
SN74HCS08DYYR
SN74HCS125DYYR
SN74HCS14DYYR
SN74HCS32DYYR
SN74HCS164DYYR
Figure 3. Newly released commercial DYY offerings and sector-based end equipment use cases
OPN
Automotive
SN74HCS74QDYYRQ1
Body electronics, Hybrid electric and powertrain systems, Infotainment and clusters
SN74HCS00QDYYRQ1
SN74HCS08QDYYRQ1
SN74HCS125QDYYRQ1
SN74HCS14QDYYRQ1
SN74HCS32QDYYRQ1
SN74HCS164QDYYRQ1
Figure 4. Newly released automotive DYY offerings and sector-based end equipment use cases
References and Additional Resources
Texas Instruments Logic Guide
16 Pin DYY Test Board User's Guide
Texas Instruments Package Selection Tool
Texas Instruments Logic Devices
