Part Number: TXB0108
Other Parts Discussed in Thread: TXB0104, SN74AXC8T245, TXU0304, TXU0104, TXU0204, SN74AXC4T774
there is a clarification required on the data rates mentioned in the data sheet of the mentioned part TXB0108DQSR . Our requirement is to make an 8 bit level translator between 1.8V logic to 3.3V logic.
The VCCA (reference voltage ) is set as 1.8V. It is mentioned in the data sheet to have a capability of 60Mbps (max.) in the mentioned configuration. We would like to get a clear view on the below mentioned points
1) By data rates , do you mean the data rates of individual channels ( each channel of the 8 bit translation) OR does the data rate mentioned in the data sheet represent the net data rate of all the 8 channels together?
2) what is approx. tolerance in the mentioned data rates ?
Thank you
