Part Number: TXS0108E
Hi Support team
We have application apply the TXS0108E for SPI leavel shifter, it already built hundrand boards without problem, recently we got problem on it.
The circuit as below, the host is Marvell/OcteonTX2 with 1.8V SPI output leavel and direct connect to the TXS0108E portA, portB wire to the SPDT-TS3A24157.
When the SPDT enable the channel then the SPI signal will through SPDT to SPI Flash.
We found the new date code of TXS0108E would make the SPI clock distortion, any recommendation for this issue?
0AKG4/1AKG4 is ok, but 1CKG4/23KG4 got fail.
