SN74AHCT00: Spice model of SN74AHC and SN74AHCT
Part Number: SN74AHCT00
Other Parts Discussed in Thread: SN74AHCT02, SN74AHC02
Hi,team
My customer has the question about Spice model of SN74AHC and SN74AHCT,
The following is my customer's description.
I am checking the difference in output voltage response when the input voltage exceeds the threshold (VIH) between the SN74AHC02/32 and SN74AHCT02/32 using LT spice wiht Spice model which downloaded form your website. However, the results are the same for AHC and AHCT although VIH of AHCT is lower than AHC when Vcc is 5V. When comparing the descriptions in the Spice model, AHC and AHCT have the same values except for the part number. Are these Spice models correct?
What I want to ask is about the descriptions within these models.
The attached file is a text version of the spice file downloaded from TI HP.
Comparing the contents, everything is the same except for MPN, and there is no difference in behavior in simulation.
However, there are differences in values such as VIH, VIL, and tp in the datasheet.
Are these values not reflected in the Spice model?
SN74AHC02 datasheet
SN74AHCT02 datasheet
Re
* SN74AHC02.cir
* 1.0
* 2018-11-13 00:00:00
* Texas Instruments Incorporated.
* Standard Logic, SLHR
* 12500 TI Blvd
* Dallas, TX -75243
* Revision History:
* Rev 2.0: 01/01/2019
* - Model generated from datasheet values
* - Built using generic logic gate behavioral pspice model V2
* - Built using an automated model which generalizes parts under same family
* - Performance is expected typical behavior at 25C
* - Written for and tested with Tina-TI Version 9.3.100.244 SF-TI
* - Accurate power consumption with dyanmic as well as static Icc
*[Disclaimer]
* This model is designed as an aid for customers of Texas Instruments.
* TI and its licensors and suppliers make no warranties, either expressed
* or implied, with respect to this  model, including the warranties of
* merchantability or fitness for a particular purpose. The model is
* provided solely on an "as is" basis. The entire risk as to its quality
* and performance is with the customer.
*[Copyright]
*(C) Copyright 2019 Texas Instruments Incorporated.All rights reserved.
*                                 SN74AHC02
.SUBCKT SN74AHC02 Y A B VCC AGND
XU1 Y A B VCC AGND LOGIC_GATE_2PIN_OD_LVC_2i_NOR_PP_CMOS_SN74AHC02
.ENDS
.SUBCKT LOGIC_GATE_2PIN_OD_LVC_2i_NOR_PP_CMOS_SN74AHC02 OUT A B VCC GND
.PARAM VCC_ABS_MAX = 7
.PARAM VCC_MAX = 5.5
.PARAM RA = 2200000000
.PARAM RB = 2200000000
.PARAM CA = 1e-11
.PARAM CB = 1e-11
.PARAM ROEZ = 2000.0000000000016
.PARAM COEZ = 1e-11
RA  A  GND {RA}
RB  B  GND {RB}
CA  A  GND {CA}
CB  B  GND {CB}
XUA NA A VCC GND LOGIC_INPUT_LVC_2i_NOR_PP_CMOS_SN74AHC02
XUB NB B VCC GND LOGIC_INPUT_LVC_2i_NOR_PP_CMOS_SN74AHC02
XUG NA NB NOUTG VCC GND LOGIC_FUNCTION_2_LVC_2i_NOR_PP_CMOS_SN74AHC02
XOUTPD NOUTG NOUTTPD VCC GND TPD_LVC_2i_NOR_PP_CMOS_SN74AHC02
XUOUT NOUTTPD NOUT_INT VCC GND LOGIC_PP_OUTPUT_LVC_2i_NOR_PP_CMOS_SN74AHC02
XICC VCC GND NVIOUT LOGIC_ICC_LVC_2i_NOR_PP_CMOS_SN74AHC02
SICC VCC GND VCC GND SW1
H1 NVIOUT GND VIOUT 1
VIOUT NOUT_INT OUTsw 0
SIOFF OUTsw OUT VCC GND SW2
DA2 GND A D1
DB2 GND B D1
DO2 GND OUT D1
RDA1 NA1 GND 1e6
SDA1 NA1 A VCC GND SW2
RDB1 NB1 GND 1e6
SDB1 NB1 B VCC GND SW2
RDO1 NO1 GND 1e6
SDO1 NO1 OUT VCC GND SW2
.MODEL SW1 VSWITCH VON = {VCC_ABS_MAX} VOFF = {VCC_MAX} RON = 10 ROFF = 60e6
.MODEL SW2 VSWITCH VON = {0.55} VOFF = {0.45} RON = 10m ROFF = 100e6
.MODEL D1 D
.ENDS
.SUBCKT LOGIC_INPUT_LVC_2i_NOR_PP_CMOS_SN74AHC02 OUT IN VCC VEE
.PARAM STANDARD_INPUT_SELECT = 1
.PARAM SCHMITT_TRIGGER_INPUT_SELECT = 0
ESTD_THR VSTD_THR VEE TABLE {V(VCC,VEE)} =
+(1,0.5)
+(1.8,0.9)
+(2.5,1.25)
+(3.3,1.65)
+(5,2.5)
+(6,3)
ETRP_P VTRP_P VEE TABLE {V(VCC,VEE)} =
+(4.5,1.7)
+(6,2.1)
ETRP_N VTRP_N VEE TABLE {V(VCC,VEE)} =
+(4.5,0.9)
+(6,1.2)
EHYST VHYST VEE TABLE {V(VCC,VEE)} =
+(4.5,0.4)
+(6,0.6)
ETRUE NTRUE VEE VALUE = {V(VCC,VEE)}
EFALSE NFALSE VEE VALUE = {0}
EBETA BETA VEE VALUE = {V(VHYST,VEE)/(V(NTRUE,VEE) - V(NFALSE,VEE) + V(VHYST,VEE))}
EFB NFB VEE VALUE = {(1 - V(BETA,VEE))*V(IN,VEE) + V(BETA,VEE)*V(CURR_OUT,VEE)}
EREF NREF VEE VALUE = {0.5*(1 - V(BETA,VEE))*(V(VTRP_P,VEE) + V(VTRP_N,VEE))
+ + 0.5*V(BETA,VEE)*(V(NTRUE,VEE) + V(NFALSE,VEE))}
EDIFF NDIFF VEE VALUE = {V(NFB,NREF)}
ESWITCH VSWITCH VEE VALUE = {0.5*(-SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
ESWITCH1 VSWITCH1 VEE VALUE = {0.5*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
GCOMP VEE CURR_OUT VALUE = {SCHMITT_TRIGGER_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
GSTD VEE CURR_OUT VALUE = {STANDARD_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(IN,VSTD_THR)) + ABS(SGN(V(IN,VSTD_THR))))}
ROUT CURR_OUT VEE 1
EMID MID VEE VALUE = {0.5*(V(VCC,VEE) + V(VEE))}
EARG NARG VEE VALUE = {V(CURR_OUT,VEE) - V(MID,VEE)}
EOUT OUT VEE VALUE = {0.5*(SGN(V(NARG,VEE)) + ABS(SGN(V(NARG,VEE) ) ) )}
.PARAM MAXICC = .0009
.PARAM VT = .7
.PARAM VCC_MIN = 3
EV_VT1 VTN VEE VALUE = { VT }
EV_VT2 VTP VEE VALUE = { V(VCC,VEE) - VT }
ETEST TEST VEE VALUE = {.9*V(VCC,VEE)}
EVTHDIFF VTH_DIFF VEE VALUE = {V(IN,VSTD_THR)}
EVTHPDIFF VTHP_DIFF VEE VALUE = {V(IN,VTRP_P)}
EVTHNDIFF VTHN_DIFF VEE VALUE = {V(IN,VTRP_N)}
EVTNDIFF VTN_DIFF VEE VALUE = { V(IN,VTN) }
EVTPDIFF VTP_DIFF VEE VALUE = { V(IN,VTP) }
GICCVA VCC VEE VALUE = { (-ABS(( (1+SGN(V(VTN_DIFF,VEE)) ) )/2 -1) *
+ 2*MAXICC*((V(IN,VEE)-VT)/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH,VEE)}
GICCVB VCC VEE VALUE = { (ABS(( (1+SGN(V(VTHP_DIFF,VEE)) ) )/2 -1) *
GICCVC VCC VEE VALUE = { ( ABS(  (1+SGN(V(VTHN_DIFF,VEE)) ) )/2  *
+ 2*MAXICC*((V(IN,VEE)-(V(VCC,VEE)-VT))/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH1,VEE)}
GICCVD VCC VEE VALUE = { (-ABS(  (1+SGN(V(VTP_DIFF,VEE)) ) )/2  *
.ENDS
.SUBCKT LOGIC_FUNCTION_2_LVC_2i_NOR_PP_CMOS_SN74AHC02 A B OUT VCC VEE
.PARAM AND  = 0
.PARAM NAND = 0
.PARAM OR   = 0
.PARAM NOR  = 1
.PARAM XOR  = 0
.PARAM XNOR = 0
GAND  VEE N1 VALUE = {AND*V(A,VEE)*V(B,VEE)}
GNAND VEE N1 VALUE = {NAND*(1 - V(A,VEE)*V(B,VEE))}
GOR   VEE N1 VALUE = {OR*(MIN(V(A,VEE) + V(B,VEE),1))}
GNOR  VEE N1 VALUE = {NOR*(1 - MIN(V(A,VEE) + V(B,VEE),1))}
GXOR  VEE N1 VALUE = {XOR*((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE)))}
GXNOR VEE N1 VALUE = {XNOR*(1 - ((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE))))}
RN1 N1 VEE 1
EOUT OUT VEE N1 VEE 1
.ENDS
.SUBCKT TPD_LVC_2i_NOR_PP_CMOS_SN74AHC02 IN OUT VCC VEE
.PARAM TPDELAY1 = 1N
.PARAM RS = 10K
.PARAM CS = {-TPDELAY1/(RS*LOG(0.5))}
ETPDNORM NTPDNORM VEE TABLE {V(VCC,VEE)} =
+(3.3,6.7)
+(5,4.6)
G1 IN N1 VALUE = {V(IN,N1)/(V(NTPDNORM,VEE)*RS)}
RZ IN N1 10G
C1 N1 VEE {CS}
E1 N2 VEE VALUE = {0.5*(1 + SGN(V(N1,VEE) - 0.5))}
EOUT OUT VEE N2 VEE 1
.ENDS
.SUBCKT LOGIC_PP_OUTPUT_LVC_2i_NOR_PP_CMOS_SN74AHC02 IN OUT VCC VEE
EROH NROH VEE TABLE {V(VCC,VEE)} =
+(2,2000)
+(3,105)
+(4.5,70)
EROL NROL VEE TABLE {V(VCC,VEE)} =
+(2,2000)
+(3,90)
+(4.5,46.25)
E1 N1 VEE VALUE = {V(VCC,VEE)*V(IN,VEE)}
GOUT N1 OUT VALUE = {V(N1,OUT)*(V(IN,VEE)/V(NROH,VEE) + (1 - V(IN,VEE))/V(NROL,VEE))}
.ENDS
.SUBCKT LOGIC_ICC_LVC_2i_NOR_PP_CMOS_SN74AHC02 VCC VEE VIOUT
.PARAM ICC = 5e-09
.PARAM VCC_MIN = 2
GICC VCC VEE VALUE = {ICC*0.5*(1 + SGN(V(VCC,VEE) - VCC_MIN))}
EGNDF GNDF 0 VALUE = {0.5*(V(VCC) + V(VEE))}
GOUTP VCC GNDF VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
GOUTN GNDF VEE VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
.ENDS
* SN74AHC02.cir
* 1.0
* 12500 TI Blvd
* Dallas, TX -75243
* Revision History:
*[Disclaimer]
*[Copyright]
*                                 SN74AHC02
.SUBCKT SN74AHCT02 Y A B VCC AGND
XU1 Y A B VCC AGND LOGIC_GATE_2PIN_OD_LVC_2i_NOR_PP_CMOS_SN74AHCT02
.ENDS
.SUBCKT LOGIC_GATE_2PIN_OD_LVC_2i_NOR_PP_CMOS_SN74AHCT02 OUT A B VCC GND
.PARAM CA = 1e-11
.PARAM CB = 1e-11
.PARAM COEZ = 1e-11
RA  A  GND {RA}
RB  B  GND {RB}
CA  A  GND {CA}
CB  B  GND {CB}
XUA NA A VCC GND LOGIC_INPUT_LVC_2i_NOR_PP_CMOS_SN74AHCT02
XUB NB B VCC GND LOGIC_INPUT_LVC_2i_NOR_PP_CMOS_SN74AHCT02
XUG NA NB NOUTG VCC GND LOGIC_FUNCTION_2_LVC_2i_NOR_PP_CMOS_SN74AHCT02
XOUTPD NOUTG NOUTTPD VCC GND TPD_LVC_2i_NOR_PP_CMOS_SN74AHCT02
XUOUT NOUTTPD NOUT_INT VCC GND LOGIC_PP_OUTPUT_LVC_2i_NOR_PP_CMOS_SN74AHCT02
XICC VCC GND NVIOUT LOGIC_ICC_LVC_2i_NOR_PP_CMOS_SN74AHCT02
DA2 GND A D1
DB2 GND B D1
DO2 GND OUT D1
RDA1 NA1 GND 1e6
RDB1 NB1 GND 1e6
RDO1 NO1 GND 1e6
.MODEL D1 D
.ENDS
.SUBCKT LOGIC_INPUT_LVC_2i_NOR_PP_CMOS_SN74AHCT02 OUT IN VCC VEE
+(1,0.5)
+(1.8,0.9)
+(2.5,1.25)
+(3.3,1.65)
+(5,2.5)
+(6,3)
+(4.5,1.7)
+(6,2.1)
+(4.5,0.9)
+(6,1.2)
+(4.5,0.4)
+(6,0.6)
ROUT CURR_OUT VEE 1
.PARAM VT = .7
.PARAM VCC_MIN = 3
.ENDS
.SUBCKT LOGIC_FUNCTION_2_LVC_2i_NOR_PP_CMOS_SN74AHCT02 A B OUT VCC VEE
.PARAM AND  = 0
.PARAM NAND = 0
.PARAM OR   = 0
.PARAM NOR  = 1
.PARAM XOR  = 0
.PARAM XNOR = 0
RN1 N1 VEE 1
.ENDS
.SUBCKT TPD_LVC_2i_NOR_PP_CMOS_SN74AHCT02 IN OUT VCC VEE
.PARAM RS = 10K
+(3.3,6.7)
+(5,4.6)
RZ IN N1 10G
C1 N1 VEE {CS}
.ENDS
.SUBCKT LOGIC_PP_OUTPUT_LVC_2i_NOR_PP_CMOS_SN74AHCT02 IN OUT VCC VEE
+(2,2000)
+(3,105)
+(4.5,70)
+(2,2000)
+(3,90)
+(4.5,46.25)
.ENDS
.SUBCKT LOGIC_ICC_LVC_2i_NOR_PP_CMOS_SN74AHCT02 VCC VEE VIOUT
.PARAM ICC = 5e-09
.PARAM VCC_MIN = 2
.ENDS
gards,
Katherine
