SN74LV1T32: SN74LV1T32DCKR
Part Number: SN74LV1T32
SN74LV1T32DCKR:
When the VCC is 1.8V, the typical propagation delay time is 10.5ns, and the maximum value is 11ns. Do you have the minimum delay time data? Thanks a lot !
  • Hi Ding,
    Generally what the data we have in the datasheet is what we have. If the information is not there it was not tested for/not too important.
    Can I ask why do you need minimum delay time data?
  • We have a signal that needs to be converted from 1.2V to 1.8V, but the skew of time delay is required to be controlled within 3ns, and I don't know if there is a recommended selection. Thanks a lot.
  • Hi Ding,
    At 1.8-V supply, the LVxT family will have a fairly broad range of possible delays, depending on process, voltage supply, and temperature variations (PVT).
    I'm afraid I don't know of any manufacturer that would guarantee a single supply voltage translating gate to have less than 3 ns of variation across PVT, especially with a 1.8V supply, where the device has the largest delays.
