[FAQ] Level Shifter Naming Convention
The level shifter portfolio at Texas Instruments is vast, with hundreds of devices and packages.
When you come across one of TI’s voltage translators, how do you quickly decipher what the name means? This naming guide above can be used for you to quickly sort through up to 18 characters.
We suggest you start with the family name, then the bit/channel count, then direction pin (if applicable) and then finally, the package.
Translate the meaning of TI’s part numbers with the Naming Convention Guide below:
