SN74AVC4T234: Can u please Verify SN74AVC4T234 Schematic Implementation attached in description page
Part Number: SN74AVC4T234
Other Parts Discussed in Thread: SN74AUC17, SN74AUC125, SN74AUC34
Hi Team,
    Can u please Verify the attached Schematic & provide me the Improvements.
   Currently we are using it for 100 MHz Clock..In datasheet recommended 26 ohm series resistors on A-Side outputs,Does series resistor needed?
With regards,
Ganesh.P
  • The datasheet does not recommend that you add series resistors. The remark in section 1 says that the device already has internal series resistors.
    The schematic looks OK. But both supply voltages are the same; why are you using a translator? A simple buffer like the SN74AUC34/​SN74AUC17/​SN74AUC125 would be cheaper and faster.
