Part Number: TXS0104E
Hi Team,
We are using the Level translator IC TXS0104EYZTR, we are facing one issue.
without clock in 1.8V side, 3.3V side we are getting clock high 3.3V.
Sathya Priya N
Hi Team,
Sathya Priya N
Hey Sathya,
Similar to what Clemens' mentioned, this is expected due to the internal pullups of the TXS. You may also remove external pullups in the schematic as well to avoid creating a voltage divider with the internal pullups.
Jack
Hi Clemens and Jack,
Thanks for the input. We will try to remove the external pull up and try testing it.
Sathya Priya N
That will not change the behaviour because there still is the internal pull-up.
What output signal do you want to see?
