Hi TI team,
I'm using some mux and buffer for JTAG application.
Need TI team to review the application in terms of correctness of part select, pull up/low resistor which concerning about active bus-hold feature.
Thanks.
Hi TI team,
Thanks.
Pull-up/-down resistors should not be used together with bus-hold inputs. (Bus hold works like a pull-up or pull-down, depending on the last state.)
Hi Clemens,
Let me add some question:
1. The bus hold feature only applicable for buffer's input side right?
2. Can you explain more on "If both have similar drive strength, and if they pull in different directions, then the resulting voltage is invalid."?
Great thanks.
