Part Number: CD74HC4094
Hi Team,
I understand that Qx outputs when STR is High in this device.
However, Qx also outputs when STR is Low.
Please see the attached waveform.
This behavior occurs randomly.
It has been observed in two products applied PCN#20220628000.1.
It has not been observed in products prior to PCN.
The customer do ABA swap, this behavior moved to other board.
I suspect it may be failure, is there anything that you think might be the cause in how they are using it?
