TPLD1201: Regarding the OTP memory of the TPLD1201
Part Number: TPLD1201
Hi team,
Once the OTP memory of the TPLD1201 is programmed using InterConnectStudio, it becomes a permanent program and cannot be rewritten. Is this understanding correct?
During the design phase, you are configuring the logic circuits and demonstrating them using EVM through InterConnectStudio, right? At this point, you are not writing to the OTP memory, so if the power is turned off, the designed data will not remain on the TPLD. Is that correct?
By the way, it seems that the program written before remains on the EVM even after the power is turned off. Does the EVM have a separate memory installed?
Kyohei
