SN74LVC1G126: SN74LVC1G126 output pulled up using a different source
Part Number: SN74LVC1G126
Hi team,
I was planning to use the IC SN74LVC1G126  for a buffered isolation application between SoC and PMIC pins. The output of Buffer is given to PMIC which has the pin pulled up by a different source other than the source powering the buffer IC. The voltage levels are same, but still wanted to confirm will this create any issue.
And also I was thinking to use a open drain buffer, but I couldn't find any with enable pin availability. Can you please suggest any if available.
