Hi
A customer has a question. The blue circle dotted line in the red empty frame is not in the green area (copper foil layer). Can this achieve the heat dissipation effect?
Or does it have another effect? Please help to confirm,
Hi
Yes, this can achieve the desired heat dissipation. It is recommended to connect the ground pad to the ground layer through vias to achieve optimal heat dissipation.
Niranjan
