Part Number: SN74AVC2T245
Other Parts Discussed in Thread: TXU0102, TXU0202
Is it possible to perform A to B (B to A) level shift with the circuit shown below?
This is the first time to use this IC, so I would like to check it.
Hello Yuma,
Yes schematic looks correct. If DIR is pulled High, data will flow from A to B. If DIR is pulled Low, data will flow from B to A.
I would recommend using a weak pull-up resistor on OE pin to maintain I/Os in a Hi-Z state until the device is powered up. This helps avoid any output glitches from occurring during power-up.
Josh
