Part Number: SN74LVC1GU04
Other Parts Discussed in Thread: SN74LVC1G04, SN74LVC1G14,
HI Team,
Can you share tr/tf spec?
is it 10ns/V?
Vidya
HI Team,
is it 10ns/V?
Vidya
See [FAQ] What is the output transition rate for a logic device?
What is the intended application? The unbuffered inverter is usually used as an analog amplifier in a crystal oscillator.
Hi Clemens,
what is the difference between SN74LVC1G04 Vs SN74LVC1GU04?
Vidhya
what will be the impact on tr /tf for unbuffered device using as logic inverter?
Output of inverter gate shows leakage of 2.5V (red graph). why?
can add a 4.7K pull down at output?
Vidhya
