Part Number: TXB0104
Hi Team,
What state are the TXB0104 outputs in, when input is high impedance and device is enabled (OE = high)?
Thank you,
-Kevin
Hi Team,
Thank you,
-Kevin
Hi Kevin,
The I/Os are in a buffer-loop with both ports driven to the same logic state. The outputs in this case will be driven to its last known logic state before input went HIGH-Z. If the randomness is not preferred, OE can be driven low to also place outputs in HIGH-Z.
Jack
