Part Number: SN74HCS541
Is a pull up resistor required on the outputs? What if outputs are always enabled?
Hi Terry,
Not sure why every single input/output type is in the datasheet. I'm assuming what you are referring to is an open-drain output. This device does not have open-drain outputs.
Unused outputs for this device can be left floating.
