Other Parts Discussed in Thread: SN74AUC244, SN74AUC34, TXV0108-EVM
From the datasheet this info cannot be found, please advise:
from 3.3V Port A to 1.2V Port B, is the data speed 100MHz (200Mbps) supported? If not, what is the maximum speed with this setting?
If TXV0108-Q1 does not support 100MHz data rate as above setting, can you please recommend a pin compatible alternative part?
Thanks.
