Part Number: TXS0102
Other Parts Discussed in Thread: LSF0102
I want to use TXS0102 on my design to translate I2C lines at 100kHz and 400kHz.
- Seen this device has edge accelerators to improve rise times. what is the maximum bus capacitance so that this device is able to drive lines for proper operation and signal integrity? 20cm PCB trace is problem for device?
- What is the recommend value for pull-down resistor for OE pin? Do I need an open drain out to drive this OE pin? I want to enable/disable this device through an FPGA pin with LVCMOS18 type output. Is it OK?
