TPLD1201: Some question about TPLD1201..
Part Number: TPLD1201
Hi Team,
1. The attached file is the configuration file. Please help to check any problems or not and provide advice for it!
 * These arguments were used when this file was generated. They will be automatically applied on subsequent loads
 * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
 * @cliArgs --device "TPLD1201_RWB_TR" --part "Default" --package "RWB (X2QFN, 12)" --product "TPLD@1.5.1+1087"
 * @v2CliArgs --device "TPLD1201" --package "RWB (X2QFN, 12)" --product "TPLD@1.5.1+1087"
 * @versions {"tool":"1.24.1+4189"}
 * Import the modules used in this configuration.
const ACMP       = scripting.addModule("/ti/tpld/ACMP", {}, false);
const ACMP1      = ACMP.addInstance();
const ACMP2      = ACMP.addInstance();
const DFF        = scripting.addModule("/ti/tpld/DFF", {}, false);
const DFF1       = DFF.addInstance();
const DFF2       = DFF.addInstance();
const DFF3       = DFF.addInstance();
const DLY        = scripting.addModule("/ti/tpld/DLY", {}, false);
const DLY1       = DLY.addInstance();
const DLY2       = DLY.addInstance();
const DLY3       = DLY.addInstance();
const DLY4       = DLY.addInstance();
const GND        = scripting.addModule("/ti/tpld/GND", {}, false);
const GND1       = GND.addInstance();
const GND2       = GND.addInstance();
const LUT        = scripting.addModule("/ti/tpld/LUT", {}, false);
const LUT1       = LUT.addInstance();
const LUT2       = LUT.addInstance();
const LUT3       = LUT.addInstance();
const LUT4       = LUT.addInstance();
const LUT5       = LUT.addInstance();
const Label      = scripting.addModule("/ti/tpld/Label", {}, false);
const Label1     = Label.addInstance();
const Label2     = Label.addInstance();
const Label3     = Label.addInstance();
const Label4     = Label.addInstance();
const OSC        = scripting.addModule("/ti/tpld/OSC", {}, false);
const OSC1       = OSC.addInstance();
const PDLY       = scripting.addModule("/ti/tpld/PDLY", {}, false);
const PDLY1      = PDLY.addInstance();
const PIN        = scripting.addModule("/ti/tpld/PIN", {}, false);
const PIN1       = PIN.addInstance();
const PIN2       = PIN.addInstance();
const PIN3       = PIN.addInstance();
const PIN4       = PIN.addInstance();
const PIN5       = PIN.addInstance();
const PIN6       = PIN.addInstance();
const PIN7       = PIN.addInstance();
const PIN8       = PIN.addInstance();
const PIPEDELAY  = scripting.addModule("/ti/tpld/PIPEDELAY", {}, false);
const PIPEDELAY1 = PIPEDELAY.addInstance();
const Simulation = scripting.addModule("/ti/tpld/Simulation");
const VCC        = scripting.addModule("/ti/tpld/VCC", {}, false);
const VCC1       = VCC.addInstance();
const VCC2       = VCC.addInstance();
const VCC3       = VCC.addInstance();
 * Write custom configuration values to the imported modules.
ACMP1.$name      = "acmp0";
ACMP1.vref_sel   = 13;
ACMP1.low_bw     = true;
ACMP1.hw.$assign = "ACMP0";
ACMP2.$name      = "acmp1";
ACMP2.inp_sel    = 2;
ACMP2.vref_sel   = 13;
ACMP2.low_bw     = true;
ACMP2.hw.$assign = "ACMP1";
DFF1.$name      = "dff0";
DFF1.rst        = 0;
DFF1.hw.$assign = "LUT3_0_DFF2";
DFF2.$name      = "dff1";
DFF2.out_pol    = true;
DFF2.hw.$assign = "LUT2_1_DFF1";
DFF3.$name      = "dff2";
DFF3.out_pol    = true;
DFF3.rst        = 0;
DFF3.clk_pol    = true;
DFF3.hw.$assign = "LUT3_1_DFF3";
DLY1.$name      = "dly0";
DLY1.edge_sel   = 1;
DLY1.data       = 10;
DLY1.hw.$assign = "CNTDLY3";
DLY2.$name      = "dly1";
DLY2.edge_sel   = 2;
DLY2.clk_sel2   = "OSC/64";
DLY2.data       = 195;
DLY2.hw.$assign = "CNTDLY0";
DLY3.$name      = "dly2";
DLY3.clk_sel2   = "OSC/64";
DLY3.edge_sel   = 2;
DLY3.data       = 14;
DLY3.hw.$assign = "CNTDLY1";
DLY4.$name    = "dly3";
DLY4.data     = 25;
DLY4.edge_sel = 2;
scripting.probe(DLY4, "OUT", ["voltage"]);
GND1.$name = "GND0";
GND2.$name = "GND1";
LUT1.$name      = "lut0";
LUT1.function   = "NAND";
LUT1.hw.$assign = "LUT2_3";
LUT2.$name      = "lut1";
LUT2.function   = "OR";
LUT2.hw.$assign = "LUT2_2";
LUT3.$name      = "lut2";
LUT3.inputs     = 3;
LUT3.hw.$assign = "LUT3_3";
LUT4.$name      = "lut3";
LUT4.inputs     = 3;
LUT4.function   = "OR";
LUT4.hw.$assign = "LUT3_2";
LUT5.$name    = "lut4";
LUT5.function = "Table";
LUT5["2_1"]   = true;
scripting.probe(LUT5, "OUT", ["voltage"]);
Label1.$name = "*lut2 & lut3 can be combined.";
Label2.$name = "* 1/16 duty pulse generation";
Label3.$name = "* Pulse Delay";
Label4.$name = "* Pulse Width";
OSC1.$name       = "osc0";
DLY1.osc         = OSC1;
DLY2.osc         = OSC1;
DLY3.osc         = OSC1;
OSC1.force_pwron = 1;
DLY4.osc         = OSC1;
OSC1.out1_sel    = 7;
OSC1.pdiv        = 1;
OSC1.hw.$assign  = "OSC0";
PDLY1.$name      = "pflt0";
PDLY1.edge_sel   = 3;
PDLY1.time_sel   = 3;
PDLY1.hw.$assign = "PDLY_FILTER0";
ACMP1.inp       = PIN1;
PIN1.res_sel    = 3;
PIN1.$name      = "CC1";
scripting.probe(PIN1, "OUT", []);
PIN1.hw.$assign = "IO1";
PIN2.$name                   = "WAKE";
PIN2.res_sel                 = 1;
PIN2.in_ctl                  = 1;
PIN2.sim                     = "pulseSource";
scripting.probe(PIN2, "OUT", []);
PIN2.hw.$assign              = "IN0";
PIN2.pulseSource.$name       = "ti_tpld_simulationOptions_PULSE0";
PIN2.pulseSource.pulsedValue = { val: 1.8, units: "V" };
PIN2.pulseSource.pulseWidth  = { val: 70, units: "ms" };
PIN2.pulseSource.delay       = { val: 40, units: "ms" };
PIN3.$name      = "EXTPWR_WKUP";
PIN3.type       = "DOUT";
scripting.probe(PIN3, "IN", []);
PIN3.hw.$assign = "IO5";
PIN4.$name             = "RST(OD)";
PIN4.type              = "DOUT";
PIN4.out_ctl           = 1;
PIN4.load              = true;
scripting.probe(PIN4, "IN", []);
PIN4.hw.$assign        = "IO2";
PIN4.outputLoad.$name  = "ti_tpld_simulationOptions_OUTPUT0";
PIN4.outputLoad.negRes = { val: 0, units: "kΩ" };
PIN5.$name      = "CHG_INT#";
PIN5.res_sel    = 3;
PIN5.in_ctl     = 1;
scripting.probe(PIN5, "OUT", []);
PIN5.hw.$assign = "IO6";
PIN6.$name      = "SW_PWR/CC_OUT";
PIN6.type       = "DIO";
PIN6.out_ctl    = 1;
PIN6.res_sel    = 3;
PIN6.in_ctl     = 1;
scripting.probe(PIN6, "OUT", []);
scripting.probe(PIN6, "IN", []);
PIN6.hw.$assign = "IO7";
PIN7.sim                  = "pwl";
PIN7.in_ctl               = 1;
PIN7.res_sel              = 2;
PIN7.$name                = "SLEEP_CHG#";
PIN7.hw.$assign           = "IO9";
PIN7.pwl.$name            = "ti_tpld_simulationOptions_PWL0";
PIN7.pwl.steps.create(2);
PIN7.pwl.steps[0].$name   = "step0";
PIN7.pwl.steps[0].voltage = 0;
PIN7.pwl.steps[0].time    = { val: 20, units: "ms" };
PIN7.pwl.steps[1].$name   = "step1";
PIN7.pwl.steps[1].time    = { val: 500, units: "ms" };
PIN7.pwl.steps[1].voltage = 1.8;
ACMP2.inp       = PIN8;
PIN8.$name      = "CC2";
PIN8.res_sel    = 3;
scripting.probe(PIN8, "OUT", []);
PIN8.hw.$assign = "IO4";
PIPEDELAY1.$name    = "pipedelay0";
PIPEDELAY1.out1_pol = true;
PIPEDELAY1.out1_dly = 7;
scripting.probe(PIPEDELAY1, "OUT0", ["voltage"]);
scripting.probe(PIPEDELAY1, "OUT1", ["voltage"]);
const SYSTEM      = scripting.addModule("/ti/tpld/SYSTEM", {}, false);
SYSTEM.hw.$assign = "SYSTEM";
Simulation.tstep = { val: 1, units: "ms" };
Simulation.power = 1.8;
Simulation.tstop = { val: 500, units: "ms" };
VCC1.$name = "VCC0";
VCC2.$name = "VCC1";
VCC3.$name = "VCC2";
const VREF       = scripting.addModule("/ti/tpld/VREF", {}, false);
const VREF1      = VREF.addInstance({}, false);
VREF1.$name      = "vref0";
ACMP2.inm        = VREF1;
ACMP1.inm        = VREF1;
VREF1.hw.$assign = "VREF";
 * Connections between modules.
scripting.connect(ACMP1, "OUT", LUT2, "A");
scripting.connect(ACMP2, "OUT", LUT2, "B");
scripting.connect(DFF1, "OUT", LUT1, "B");
scripting.connect(DFF1, "OUT", DLY2, "IN");
scripting.connect(DFF2, "OUT", PIN6, "IN");
scripting.connect(DFF3, "OUT", PIN4, "IN");
scripting.connect(DFF3, "OUT", PIN6, "OE");
scripting.connect(DFF3, "OUT", DLY1, "IN");
scripting.connect(DLY1, "OUT", LUT4, "A");
scripting.connect(DLY2, "OUT", DLY3, "IN");
scripting.connect(DLY2, "OUT", PIN3, "IN");
scripting.connect(DLY3, "OUT", LUT1, "A");
scripting.connect(DLY4, "OUT", DFF2, "CLK");
scripting.connect(GND1, "OUT", LUT4, "C");
scripting.connect(GND2, "OUT", OSC1, "PDWN");
scripting.connect(LUT1, "OUT", DFF1, "NRST_NSET");
scripting.connect(LUT2, "OUT", DFF2, "IN");
scripting.connect(LUT3, "OUT", DFF3, "NRST_NSET");
scripting.connect(LUT4, "OUT", LUT3, "A");
scripting.connect(LUT5, "OUT", ACMP2, "PUP");
scripting.connect(LUT5, "OUT", ACMP1, "PUP");
scripting.connect(LUT5, "OUT", DLY4, "IN");
scripting.connect(OSC1, "OUT1", PIPEDELAY1, "CLK");
scripting.connect(PDLY1, "OUT", LUT4, "B");
scripting.connect(PIN2, "OUT", DFF1, "CLK");
scripting.connect(PIN5, "OUT", LUT3, "C");
scripting.connect(PIN6, "OUT", PDLY1, "IN");
scripting.connect(PIN7, "OUT", PIPEDELAY1, "NRST");
scripting.connect(PIN7, "OUT", DFF3, "CLK");
scripting.connect(PIPEDELAY1, "OUT0", LUT5, "A");
scripting.connect(PIPEDELAY1, "OUT1", PIPEDELAY1, "IN");
scripting.connect(PIPEDELAY1, "OUT1", LUT5, "B");
scripting.connect(VCC1, "OUT", DFF1, "IN");
scripting.connect(VCC2, "OUT", DFF3, "IN");
scripting.connect(VCC3, "OUT", LUT3, "B");
 * (x,y) coordinates for modules that are displayed in a graph.
ACMP1.$position      = [-40,60];
ACMP2.$position      = [-40,155];
DFF1.$position       = [-25,-85];
DFF2.$position       = [230,185];
DFF3.$position       = [525,505];
DLY1.$position       = [520,360];
DLY2.$position       = [190,-75];
DLY3.$position       = [365,-30];
DLY4.$position       = [-40,260];
GND1.$position       = [200,430];
GND2.$position       = [-315,-155];
LUT1.$position       = [500,20];
LUT2.$position       = [120,105];
LUT3.$position       = [350,445];
LUT4.$position       = [260,340];
LUT5.$position       = [-170,335];
Label1.$position     = [335,525];
Label2.$position     = [-190,420];
Label3.$position     = [215,-100];
Label4.$position     = [390,-70];
OSC1.$position       = [-260,-185];
PDLY1.$position      = [155,340];
PIN1.$position       = [-480,75];
PIN2.$position       = [-465,-55];
PIN3.$position       = [760,-60];
PIN4.$position       = [770,520];
PIN5.$position       = [-465,475];
PIN6.$position       = [765,205];
PIN7.$position       = [-465,535];
PIN8.$position       = [-480,170];
PIPEDELAY1.$position = [-285,335];
VCC1.$position       = [-85,-100];
VCC2.$position       = [460,475];
VCC3.$position       = [260,435];
VREF1.$position      = [-225,205];
 * Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
 * version of the tool will not impact the pinmux you originally saw.  These lines can be completely deleted in order to
 * re-solve from scratch.
DLY4.hw.$suggestSolution       = "LUT4_0_CNTDLY2";
LUT5.hw.$suggestSolution       = "LUT2_0_DFF0";
PIPEDELAY1.hw.$suggestSolution = "LUT3_4_PIPEDELAY";
2.  How much variation is there in the built-in 10 kohm pull-up/pull-down resistors?
Thanks.
