Hi Team,
As title, do we have appropriate solution about 1ch or 2ch inverter with enable pin. When disable the device, the output would be hi-Z.
Roy
Hi Team,
Roy
Hi Roy,
Would this part work? It is a 2ch inverter with 3-state outputs and an nOE pin:
https://www.ti.com/product/SN74LVC2G240
Ian
Hi Roy,
We do not have an automotive 1 or 2 channel inverter with enable. You can select from devices without enable here
Or devices with enable that are not automotive
If they are okay with a larger solution size we could look at turning a NAND gate into an inverter by tying the inputs of one channel together. They can select from those options here
Owen
