Part Number: TPLD801
Other Parts Discussed in Thread: TPS3422
Is TPLD801 able to replace of the TPS3422 function? Customer would like to do the push button function with timing adustable.
Brian
Hi Brian,
Yes, TPLD801 should be able to replicate this functionality. Let me know if you need help making a circuit.
Malcolm
Customer is concerned shortage in the future when products are launch ! why this is no stock in the TI store? Thanks!
Hi Brian,
There is plenty of stock for the TPLD801 beyond what is listed on TI.com.
The part number on TI.com is for blank devices, so it is unusual for a customer to order a significant quantity of devices off of TI.com. Programmed devices are given a custom part number, and we have plenty of stock for that which is not reflected on the website.
Let me know if that makes sense, or if you need me to explain it better.
Malcolm
Thanks! What is the order process of sample if customer offers the their own design program file to TI.
As previous discussion, customer wants the TPLD801 to perform the following functions as TPS3422.
Is that possible team able to design it? And to get sample with programming code.
1. 3 Input Selection,3 second, 6 second and 9 second
2. 1 output with Latch function, open collector
3. second Input Logic Requirement
Brian
Hi Brian,
Sure, we will start working on this for you. Just FYI, but with the Thanksgiving Holiday coming up, we are probably looking at two weeks here. The ordering process is simple, they can order the design through the software and the rest is automated.
Malcolm
Hello Malcolm,
May i know the timeline when to get the sample with programmed code as above SPEC? Thanks.
Brian
Hello Malcolm,
May I know the timeline when to get the sample with programmed code as above SPEC? Thanks.
Let me know if any further info. you need. thanks.
Application: Power tools.
Brian
Hi Brian,
Let's work to get the correct design this week. I will check with the team how long it takes to get samples after we have confirmed we have the correct design.
Malcolm
Thanks Lyn.
How is the progress about this? Let me know if further info. you need. thanks.
Brian
Hi Brian,
Can you let me know if this design is what you are looking for? Blue is the input, green is the output. Once the blue pulse is longer than 3 seconds, the output toggles high or low depending on its initial state. I can easily extend this design to the other two inputs and we can fit everything on a single TPLD801.
The yellow signal shows when we detect the input is longer than 3 seconds and toggle the output inside the device.
Malcolm
Hello Malcolm,
After confirming with customer, that design is ok.
Brian
Hi Brian,
Here is the full design file that has inputs and outputs for 3, 6, and 9 seconds. If you or the customer need help with ordering, please reach out to me over email at m - lyn @ ti . com
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/151/BrianWang.syscfg
Malcolm
