Part Number: CD4512B
Hi Team,
May I Know how long the selsect pins (A/B/C) need to keep to switch OK?
As customer testing, using the test program will cause the switching fail sometimes, but manual switch will not.
Please help to check.
Thanks.
Hi Team,
Thanks.
Hi Peter,
The select pins need to be held longer than the maximum "A" Select to Output + Transition time for your voltage, assuming you are using a standard loading condition. If you are driving a slow-to respond load (like a large capacitance), you may need to hold longer.
