Using the spice model in ADS
Other Parts Discussed in Thread: SN74ALVC08
Dear customer support:
I was trying to use the spice model of the sn74alvc08 component in my research project on ADS, but it didn't work: I tried first to import the library file, it was giving the following notification: Failed to find item HS_Include in item definition file "spctoiff.cfg" Plus a new design file appears in the project directory named: "NOMINAL.dsn". Then I tried to include the packages files, they were all named "UNNAMED.dsn", and finally I tried to import "sn74alvc08.inc" and include it in a testing project, the output was always zero, which means it is not working properly, and I got the following message in the import window:
WARNING: Failed opening include or library file "sop14.pkg", line #47.
Found library section reference: file=sn74alvc08_process.lib section=NOMINAL.
If this reference is to an external file, that file will not be translated
automatically. Please translate any required library files separately.
See the user's guide for instructions on how to use a translated library
section.
Please Can you help me fix this problem, I am really interested in this component, it has a very good propagation delay, which is a very important issue in my research project.
Thank you for your time.
Firas
