CD74ACT541: 4BC9XXX lot code issues
Part Number: CD74ACT541
TI chip CD74ACT541M96 lot 4BCxxxxx failure details.pptx
Texas_Instruments_PCN20231219000_20241030143715169.pdf
We are seeing failures on all boards that using the  CD74ACT541 chip with lot code 4BC9XXXX. Below is some data to support this. The attached ppt has data to support this.
I believe at this point failures can be recreated with the boards that have the 4BC9XXX lot, meaning they are not performing well for our application. We need to
  1. Understand what the serial coding means on these parts and how is it different from older lots?
  2. From the PCN, we understand that there was a change in new wafer site, die change, site manufacturing change , BOM updates, Bond wire change. Do you have data to support that there were no performance differences between the lots?
  3. Understand if TI has had any other complaints/written any SIRAs on this part.
Thank you
