NEED INFORMATION-TXS0101DBVTG4
Can you please provide the following information for the TXS0101DBVTG4 Part ?
1. Junction Temperature Max (Tj Max)
2. Typical Power, (Pd typ)
3. Maximum Power (Pd max)T
4. Thermal Resistance Junction to Board (Theta JB)
5. Thermal Resistance Junction to Case (Theta JC)
6. Weight
Jayakumara K
jayakumara.krishnasetty@honeywell.com
Tel:   +91-80-26588360   Extn: 50116
    Here is the feedback for your questions.
    [Junjie] +125oC
    [Junjie] This part has less power and also the power is related to the Vcc and input frequency, could you let us know your application? we can provide the power for it. Also you know this part can work at push pull mode (max 24MBps) and Open drain mode(max 2MBPS), so this typical power is not shown in the datasheet. if no detail application, I will give the two values for you, one is push pull at 12MBPS, the other is open drain 1MBPS with power VccA is 1.8V and VccB is 3.3V, the temperature is 25oC. do you agree with it?
    [Junjie] This max power, I will think about the worst case with max Vcc and max frequency and max temperature with it, is this want you wanted?
    [Junjie] Due to this part has less power, there is no this information in datasheet. I need to contact the thermal team to get this value, once I get it , I will let you know.
    6. Weight
    [Junjie] Will get back to you soon.
    BR
    junjie
  • HI junjie
    CAN U PLEASE PROVIDE ME REMAINING INFORMATION  FOR THE PARTS-TXS0101DBVTG4 ?
    3. Maximum Power dissipation (Pd max)-
    6. Weight
    THANKS & REGARDS
    here is the update. sorry for late.
    [Junjie] 74.5 °C/W
    [Junjie] 156.5  °C/W
    6. Weight
    [Junjie] 12.4mg
    BR
    Junjie
