We are using Schmitt Trigger CD40106B in our product to interface a water level sensor. As a part of functional test the sensor input is shorted and the signal timing is measured. This signal passes through 3 stages of schmitt trigger.
We have encountered a problem during production testing.The ICs with date code 0444 (2004 date code) passed the test whereas ICs with date code 0319 (2003 date code) - Failed.
Is there any difference between 0444 (2004) and 0319(2003) date codes for CD40106B ? The datasheet shows the latest revision as REV D Sep 2003. Kindly provide me errata or revision change history for this IC.
Thanks & Regards,
Dhaval Mehta
